Adjustable Fuel Pressure Regulator: Purchased
Old Oct 25, 2008 | 10:58 AM
boldguy's Avatar
Car: 1992 Z28
Transmission: World Class T-5 5speed manual Trans
Axle/Gears: STOCK G92 performance 3.42
So last week i bought a BBK afpr and the Accel Fuel Pressure Gage. I tried to install the gage and that piece of sh*t is nothing more than an example of **** poor engineering. Its like they never even tested it out, they just drew it up on a whiteboard and said lets make that. STUPID .
anyways so im gonna try to tweek my fuel pressure, any tips on doing this?
What are your takes on the BBK afpr?
Thanks!
Old Oct 26, 2008 | 05:21 PM
TigerVette's Avatar
Re: Adjustable Fuel Pressure Regulator: Purchased
What is wrong with the gauge to begin with?
If you don't like something, send it back with a letter that includes your feedback. Most companies want to know your feedback and will treat you right if you spend some time to explain your issues to them.
I simply hooked my AFPR up with a separate hand held FP gauge, very easy to hook up to the valve to test, then can put it away when I'm done.
Old Oct 29, 2008 | 06:00 PM
boldguy's Avatar
Car: 1992 Z28
Installed!!
wasnt too bad of an install. Stock i was at 42 PSI with the engine off. now im at 48 PSI and it runs a little smoother. I haven't really had a chance to go WOT yet , but well see. I know for sure that the car still needs a tune, because the problem still persists. I don't know if i should start a new thread or what but here it goes.
When i change from no throttle coast --to-- any throttle whatsoever, there is a loud clunk and a jerk to go along with it. sometimes it will start bucking and jerking the car back and forth, ( i dont know if this still happens since the AFPR...) does anyone have any ideas?? Currently im running the stock chip, but stock it had a 305 now its a 350 and bigger injectors-supposedly...
i tried to go through Tbichips.com but twice they both were not very good...
any ideas or suggestions???
Thanks guys!
Installed!!
Thanks guys!
Old Oct 29, 2008 | 06:27 PM
85berlinetta2.8's Avatar
Car: IROC Z
Engine: 5.7
Hows the transmission mount look
Old Oct 29, 2008 | 06:45 PM
boldguy's Avatar
Car: 1992 Z28
good thought but ive replaced the tranny mount motor mounts, cap, rotor (and they are solid), ignition module, tranny fluid, diff fluid, fuel filter, air filter oil filter, air freshener, oil, sound system, and the damn thing still does it!!!
I may have had a revelation though, while doing the research on which injctors i have, (a half hour ago) i found out that the previous owner lied about putting bigger injectors in, right now they ar the Rochester 19 lb/hr 17090882's that the 305 came with!!!!! now with a 350 in it, they are killing the performance and gas mileage!!!!
Old Oct 29, 2008 | 06:55 PM
TIMMYS89GTA's Avatar
Car: 81z-28,89gta,91z-28 03 1500
Engine: 355,L98vette tpi,327
Transmission: TH350/700R4/700r4/4l80E
Axle/Gears: 3;73/3;27/2;73/3;73
A 350 TPI engine will run OK with all 305 stock components.Like the following
Inc. inj. ecm and memcal.
If the engine has modifications like a bigger cam for example then yes,the sd tpi will need a tune.
Sounds to me maybe(perhaps) you have at least one bad inj.
unplug them with the engine cool and check them with an ohmmeter set to the 2k setting and record the differences.
Old Oct 30, 2008 | 12:07 PM
boldguy's Avatar
Car: 1992 Z28
already did it and found this:
Injector# Resistance in Ohms
1 17.1
2 16.8
3 16.8
4 17.1
5 16.8
6 16.8
7 16.8
8 16.8
any ideas about the 3 ohm difference on cylinders 1 & 4? could these be the culprit??
Old Oct 30, 2008 | 12:20 PM
boldguy's Avatar
Car: 1992 Z28
So if these injectors are in good working order...
then,
--i have heard of EFI hotrodders intentionally going with a smaller injector and cranking the fuel pressure allowing the fuel to atomize more efficiently...
any experiences?
Old Oct 30, 2008 | 03:30 PM
92 Z-28 Camaro's Avatar
Car: 1992 Z-28
Transmission: auto
1 17.1
2 16.8
3 16.8
4 17.1
5 16.8
6 16.8
7 16.8
8 16.8
Hi
I am little confused - I see 3/10 of an ohm not 3 ohms. That would not even be seen by the injector driver circuit, down in the noise.
Bill
Old Oct 30, 2008 | 06:23 PM
boldguy's Avatar
Car: 1992 Z28
sorry .3 ohms. so thats not the problem.
any opinions on the next post though?
Old Oct 31, 2008 | 06:57 AM
Car: 1992 Z-28
Transmission: auto
then,
any experiences?
Hi
I have not heard of that - I have the larger injectors with the pressure higher. I am trying to get more fuel in the engine. The injectors today atomize the fuel extremely well. If you are looking for fuel economy that may work but if you are looking for HP, more fuel (to a limit).
Bill
MustangBeater20
Oct 29, 2022 09:20 PM
specialized
Jun 18, 2022 09:26 AM
Infested
May 22, 2018 11:56 PM
dcbsracing007
Aug 18, 2015 07:24 AM
Kaweh
Aug 9, 2015 02:54 PM
