IAC difference based upon year
Old Oct 28, 2008 | 01:07 PM
Tibo's Avatar
Car: 1991 Z28 Vert
Engine: 383 single plane efi
Axle/Gears: 8.8 with 3.73s
I did searches for this question and found no answers. There is a different part number for idla air control valves (IAC) for 85-88 and 89-92 engines. Yes I know the throttle bodies had differences, but the valves appear exteriorly identical. Which makes me wonder what the difference is.
Along with that main question, does it then have an effect based upon what setup you are running, ie MAP or MAF.
I run a 85-88 style throttle body with a MAP system. Could the passage way for the IAC possibly be a different length?
Old May 1, 2012 | 01:23 PM
DBRjeep350TPI's Avatar
Re: IAC difference based upon year
I am wondering this exact same thing??? Dose anyone have an answer????????
Old May 1, 2012 | 09:41 PM
Tibo's Avatar
Car: 1991 Z28 Vert
Only thing I could ever find out is that the pinnings (ie IAC coil A/B hi/lo) appear to be identical. Also I found out that the IAC valves for LT1 and LS1 throttle bodies can be used without any real problem as long as the pinning is correct. I stopped worrying about it, but I still wonder about it....
specialized
Jun 18, 2022 09:26 AM
mdtoren
Aug 23, 2015 12:52 PM
mdtoren
Aug 16, 2015 05:45 PM
Fronzizzle
Aug 9, 2015 01:15 PM
