data connector....
Old Nov 5, 2008 | 12:39 PM
nascar2496's Avatar
Car: 1986 Camaro IROC-Z
Engine: 305 tpi
Transmission: BW t5 W/ short shifter
Axle/Gears: 9 Bolt 3.27 posi
data connector....
ok, so my car was originally a 305 4bbl carb (lg4 i believe), I am in the process of converting it to tpi because i am sick of after market carbs but anyways. my question is do i have to change the data connector and wires in my car to one that was used in a tpi car?
if so, does anyone have one?
Old Nov 5, 2008 | 01:08 PM
jv9999's Avatar
Car: '87 IROC/'68 SS
Engine: 5.7L/350
Transmission: 700R4/Muncie 4-spd
Axle/Gears: 3.27 9 bolt / 3.31 12 bolt
Re: data connector....
Not sure what you're really asking here. You'll need a TPI harness with a compatible ECM, a TPI chip, and all the sensors.
Old Nov 5, 2008 | 01:57 PM
nascar2496's Avatar
Engine: 305 tpi
I mean the adl connecter under the dash on the drivers side, you know for the engine codes and such. I was simply wondering if the current carb computers connector is the same as the TPI computers connector/wires. I have the computer and wiring harness..sensors are on the way but i want to make sure i have everything ready to go before i start the car for the first time.
Old Nov 5, 2008 | 03:19 PM
jv9999's Avatar
Engine: 5.7L/350
The ODB/ALDL connector is the same.
Old Nov 7, 2008 | 10:15 PM
nascar2496's Avatar
Engine: 305 tpi
can anyone confirm this? I am hearing from another site its different and the dash harness needs to be changed.
Old Nov 11, 2008 | 08:46 PM
nascar2496's Avatar
Engine: 305 tpi
anyone?
Old Nov 11, 2008 | 08:51 PM
Ward's Avatar
Car: 1988 GTA
Engine: 5.0 TPI
Axle/Gears: 9 Bolt, 3.45
The connector itself is the same, but it's part of the ECM underdash harness. Certain pins are present on certain years/engines too. For example, the TPI ALDL will have the fuel pump test pin, the LG4 will not. If you have a TPI donor car, I'd recommend just swapping the entire underdash harness.
Old Nov 13, 2008 | 08:55 PM
nascar2496's Avatar
Engine: 305 tpi
Yeah im coming into a tpi donor car soon, im taking the under dash wiring cause i looked at my aldl and a pic of a tpi its def different. so now i get to learn how to change a harness...
Old Nov 21, 2008 | 10:55 PM
nascar2496's Avatar
Engine: 305 tpi
yeah...just got the donor harness out of the tpi car..same year as mine...and oh god what a pita. I almost want to sell my car and just buy one with tpi.
Old Nov 22, 2008 | 09:18 AM
tinymay's Avatar
Engine: 5.7 TPI
Now the FUN begins... install time!!!
Falcon50
Aug 22, 2020 03:26 PM
L98GTA87
Oct 19, 2015 10:43 PM
bjpotter
Oct 4, 2015 07:48 PM
MitcherNeaf
Sep 24, 2015 09:23 PM
BWilcox
Sep 20, 2015 12:19 PM
