355ci setups?
Old Nov 6, 2008 | 02:52 AM
87_355ci_Camaro's Avatar
Car: 86 Iroc-Z
Engine: 310ci soon to be 355ci
Transmission: built 700r4
Axle/Gears: I think 3.08s
355ci setups?
Anyone know what's a good setup on a 355cu 2blt such as bigger cam,heads,ignition setups, I'm lookin to keep the tpi or go stealth ram. Was kinda lookin for 400hp. I was lookin at comp cams xfi 366cam hedman LTs, dart iron eagle 200cc heads, summit 58mm tb. If anyone knows a better setup please reply. Thanks guys
Old Nov 7, 2008 | 12:57 PM
bjankuski's Avatar
Car: 1988 Firbird
Engine: 406
Axle/Gears: 4.10
Re: 355ci setups?
Look at my sig.
Old Nov 7, 2008 | 01:10 PM
Car: 86 Iroc-Z
Re: 355ci setups?
Originally Posted by bjankuski
Look at my sig.
What's the lift and duration on the cam? Hsr the same power maker as the super ram? Thanks
Old Nov 7, 2008 | 01:20 PM
Kevin91Z's Avatar
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
Re: 355ci setups?
Several people have posted their setups all over this board.
Can you tune your own chips or do you know someone who can? 400 HP wont be possible on the stock chip.
87+ Roller cam block
Comp XFI268HR-113 camshaft (218/224, .560/.570" lift w/ 1.6, 113 LSA)
Trick Flow 195 or AFR Eliminator 195 heads
Either HolleyStealth Ram or Edelbrock TPI intake and SLP or AS&M siamesed runners
Dyno Don 1 3/4" headers
Don's dual cat ypipe or single cat y-pipe
Any 3" or 3.5" cat-back exhaust, your choice
And the required chip tuning
That'll get you 400+ horsepower and 12 second ET's at a sea level track. It'll also be plenty streetable to use as a daily driver with decent gas mileage.
Old Nov 7, 2008 | 01:24 PM
Car: 86 Iroc-Z
Re: 355ci setups?
That's what I'm tryin to find, a good tuner. There's not many ppl do up here in pa unless I go to philli and that's about 3hrs away. Thanks for the info dart heads any good I can't really fork out 1300 for heads
Old Nov 22, 2008 | 09:35 PM
Car: 86 Iroc-Z
Re: 355ci setups?
I dont have a roller block I have Hydraulic flat tappet. Would a retro fit kit work for that cam?
hectre13
Car Audio
26
Mar 3, 2022 05:38 PM
LT1Formula
Oct 8, 2015 08:34 PM
meeklay812
Oct 1, 2015 03:46 PM
dusterbd
Sep 29, 2015 08:40 AM
Badass355ciz28
Sep 28, 2015 08:31 PM
