bypassing vats-no key
Old Nov 21, 2008 | 09:54 PM
77tpi nova's Avatar
i read the tech article on bypassing the vats, but my donor car didn't have a key. do i have to get an aftermarket chip now? any suggestions on the chip, motor will be close to stock.
Old Nov 21, 2008 | 10:01 PM
mexicanknight's Avatar
Re: bypassing vats-no key
i think its just a plain old resistor you use t bypass the vats module
Old Nov 22, 2008 | 04:39 PM
brians88gta's Avatar
Car: 88 gta
Engine: 350 HSR
Axle/Gears: 3:27 borg warner 9 bolt
u have to go to the dealer so they can see what resistor is needed for the vats then get a key test resistance on the key then solder in the right resistor
Old Nov 22, 2008 | 04:56 PM
Atilla the Fun's Avatar
On Probation
Engine: several
Transmission: none
Axle/Gears: none
Or you can just get the list of the 13 different resistances, go to Radio Shack, buy a pack of resistors, and try all 13, one at a time, like I did. Took me an entire saturday, but it turned out fine.
Old Nov 22, 2008 | 11:06 PM
77tpi nova's Avatar
thats what i'll probally try,would be cheaper than a new chip fo sho
$750 L98
Feb 1, 2025 02:25 PM
RS Reaper
Oct 17, 2018 07:52 PM
Gunner242
Dec 25, 2015 04:49 PM
Linson
Oct 1, 2015 09:50 PM
IROC ZELLER
Sep 29, 2015 03:00 PM
