Best cam for 305 tpi
Old Nov 8, 2008 | 08:35 PM
Rocksiroc's Avatar
I have an 86 iroc z and am looking to swap in a bigger cam and heads.
Im looking at the lt4 hotcam kit and world sr torquer 305 heads
would this be a good setup i see that mr brisk is using the hotcam and his car sounds mean as hell.
I already have a full exhaust system, heddman shorty headers, american thunder catback 3" and an exhaust cutout.
Im looking to make around 300 hp at the motor with the cam and heads.
Also any recomendations for upgrading the intake side.
I was thinking maybe a superram or edelbrock set up.
Old Nov 10, 2008 | 01:15 AM
Kevin91Z's Avatar
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
Re: Best cam for 305 tpi
If your engine is stock from '86, then you have a flat-tappet cam, and the LT4 HOT cam is a roller cam. You would need aftermarket roller lifters and a front timing chain adaptor to use the LT4 cam or any other roller cam.
gta90
Sep 15, 2015 04:00 PM
drewdock87
South Central
Aug 18, 2015 09:02 PM
st.evel07
Aug 13, 2015 06:15 PM
Sanjay
Aug 12, 2015 03:41 PM
drathaar907
Aug 6, 2015 04:20 PM
