305 tbi to 350 tpi swap.
Old Nov 12, 2008 | 06:36 PM
tillerZ28's Avatar
I have a 305 tbi in my 91 Camaro rs I found a 350 tpi from http://www.hawksthirdgenparts.com/ca...accessory.aspx
It says it comes with engine, wiring harness, computer and accessories( I'm pretty sure they mean pulleys) but what else am I gonna need to perform this swap correctly with no problems. I read from previous threads that the tbi is worth nothing in terms of power. This is why I wanna swap it to the correct engine. Just give me a list of all the parts needed or a website that shows me everything that is needed for the swap. Thank you.
Old Nov 13, 2008 | 11:08 AM
Dyno Don's Avatar
Transmission: Tremec T-56
Axle/Gears: 12 Bolt 3.73
Re: 305 tbi to 350 tpi swap.
Trust me, you need to know these cars like the back of your hand to pull off that swap.
There are so many little things that would drive you nuts if you dont know them.
With that said, it is worth it.
But, there is no way a Camaro & Firebird harness will be the same.
xkingcodex
Feb 12, 2020 07:43 PM
pimp2303
Jul 27, 2017 02:03 PM
apo_bailon15
Mar 28, 2016 05:20 AM
92purpz28
Aug 11, 2015 02:30 PM
