tpi plenum and runner modding
Old Nov 18, 2008 | 02:45 PM
ericjon262's Avatar
Car: 85 2M6, 87 'Bird 88 'burb
Engine: LX9, LG4, L05
Transmission: F23, 700r4, 700R4
Axle/Gears: 3.63, 2.73, 4.10
I was wondering if anyone has tried modding a tpi so it has two larger plenums (with some kind of balance pipe) w/ 2 separate throtle bodies? does anyone think it would work, and make better power?
Old Nov 23, 2008 | 10:22 PM
ModPog84z28's Avatar
Car: 1989 Camaro RS
Engine: 496 BBC
Transmission: T-56 6 speed
Axle/Gears: 4.11 posi
Re: tpi plenum and runner modding
i dont know if anyone has tried that, im farely new to the tpi set of things, but i think one problem would be the MAF. if you run a MAP or speed density setup, it might be possible i think, but running a single MAF for two plenums seems kinda redundant too me, and even if you ran two MAFs, think of the harness and tuning time your getting at? can you say R&D $'s?
kewl idea though, the only thing close ive seen is an SLP TPI ram intake on ebay for 2400 bux, but its still a single, looks kinda kewl though.
Old Nov 23, 2008 | 10:38 PM
scribbles's Avatar
Car: 88 gta
Engine: 350 tpi
I have ben thinking bout that for a long time. The v6 guys are doing that seems to work great.
Old Nov 24, 2008 | 10:55 PM
ericjon262's Avatar
I thought it would be interesting, but it'll be a long ways down the road, my carb works fine now(if it aint broke don't fix it!) I'll have to upgrade my whole fuel system.
I was kinda thinking of something like the T-ram in the pic without the middle and the throttles on the outsides. it might look cool but it would be ALOT of work for nothing if it won't perform!
Old Nov 24, 2008 | 11:19 PM
1989GTATransAm's Avatar
Car: 1989 GTA
Engine: 369 TPI
Axle/Gears: 3.70 Nine Bolt
I saw something similiar that was done to an LT1 intake system. A second plenum was grafted to the top of the regular plenum. Two throttle bodies were used. The upper plenum mainly fed the back 4 cylinders. The lower plenum mainly fed the front four cylinders as I remember. But the two plenums were connected. This went into a race car where hood clearance was not an issue.
Old Feb 26, 2009 | 06:32 PM
ericjon262's Avatar
awakening the dead!
This is my idea.
I got a speed density TPI off craigslist pretty cheap so I think I'm going to give it a shot.
I'm going to start off by cutting down the stock runners, maybe a little shorter than halfway. then I'm going to work on fabbing up the air boxes.
Any suggestions before I begin?
Thanks-
Eric
PS,
Please don't make fun of my paint drawing!
Old Feb 26, 2009 | 10:32 PM
Car: 1989 GTA
Engine: 369 TPI
If you connected the two plenum areas you would have the Superram.
Old Feb 26, 2009 | 10:48 PM
ericjon262's Avatar
sort of, they will be connected, but only with a balance pipe (similar to haveing an "H" or "X" pipe in your exhaust, also, the runners will prob be shorter, that drawing is more of a rough sketch than anything else, also, the superam uses the factory TB placement.
Old Feb 27, 2009 | 09:38 AM
nascar2496's Avatar
Car: 1986 Camaro IROC-Z
Engine: 305 tpi
Transmission: BW t5 W/ short shifter
Axle/Gears: 9 Bolt 3.27 posi
chrysler actually did something like this on the concord/intreped i think it was the 98ish ones....the 3.5 v6 had two throttle bodies and each was only responsible for 3 cylinders. The car moved to say the least...the only problem i see is that there is now two of everything and that much more that can fail. but go for it! it would be interesting to see it done.
Old Feb 28, 2009 | 08:48 PM
ericjon262's Avatar
The "two of everything" issue is the part I think I'm going to have trouble making work, I'll figure something out though.
Old Mar 1, 2009 | 03:19 AM
HCR13's Avatar
Car: 1987 Trans Am
Engine: 355ci L98 soon to be turbo'd
Axle/Gears: 2.73 posi
Interesting idea, *subscribing*
Old Apr 21, 2009 | 04:18 PM
Chaotic Neutral's Avatar
Car: 1985 Z28
So basically what they had for the WX-3 concept.
http://farm4.static.flickr.com/3519/...3e7ee4e1_b.jpg
http://the-perfect-exposure.blogspot...-american.html
I plan on using the same thing, for my engine build. It's not original, but still looks cool.
Old Apr 21, 2009 | 11:53 PM
HCR13's Avatar
Car: 1987 Trans Am
thats very nice...
MantyZ28
16
Dec 21, 2015 11:02 AM
stalkier
Dec 6, 2015 11:25 PM
Hawkeye1980
Aug 31, 2015 07:09 AM
Sanjay
Aug 12, 2015 03:41 PM
drathaar907
Aug 6, 2015 04:20 PM
