Air tube removal???
Old Nov 20, 2008 | 04:50 PM
GTAlover's Avatar
Car: 1986 Camaro
Axle/Gears: 4.10
Air tube removal???
Is it possible to remove the air tube that is bolted to the back of the heads that connects the passenger and driver side air tube without taking out the tranny? Can I lower the tranny and get it out? It's on a 86 TPI Auto. Thanks!
Please save your energy if you want to tell me to leave it on...
Old Nov 21, 2008 | 04:07 AM
Viprklr's Avatar
Car: 92 GTA/ 00 TA
Engine: 383/350
Transmission: 700R4/T-56
Re: Air tube removal???
Yep. If you're having too many issues unbolting it then you can cut it off.
Old Nov 21, 2008 | 03:24 PM
george 88gta's Avatar
Done it more than once. Both remove an install. A little cose to work in, but doable. You can remove the distributor and coil to get some more working room. Just make sure you reattach all of your ground wires. I use a star washer and some anti-seize, to make sure I get a good ground and prevent corrosion. Those grounds are very important.
1992 Trans Am
May 10, 2023 07:19 PM
Vintageracer
Jan 10, 2020 05:33 PM
Street Lethal
Aug 13, 2015 08:28 PM
3rdgenparts
Aug 8, 2015 07:09 PM
drathaar907
Aug 6, 2015 04:20 PM
