5.0 Liter Heads
Old Nov 30, 2008 | 04:36 PM
BC GTA's Avatar
Car: 1989 GTA
Engine: 5.0 TPI
Transmission: T-5 WC
Axle/Gears: Yukon 3.73
5.0 Liter Heads
I have been toying with the idea of getting heads for my 5.0 Litre. As you may know there are not a lot of options out there. There are the stock 081 and 187 heads. You have World Product heads. Then you get into aluminum heads. I have identified the following three aluminum heads:
Trick Flow
http://store.summitracing.com/partde...5&autoview=sku
Trick Flow
GM “Vette Heads”
If you were going to buy a set of these heads which would you choose and why? The price is about the same between these heads so that is not a consideration.
What is the advantage over one exhaust port shape (i.e. D, square, rectangular, …etc)? What are some of the more important items to consider when considering heads?
I have a cam, headers, stock intake manifold, EGR valve … etc. on a relatively new 5.0 litre.
I know about valve size, 3 angle valve jobs, unshrouding valves, a little about runner volumes and not to much more.
Also, stock combustion chamber is 58cc so reducing it to 56cc may increase compression ratio a bit.
Cleotiz
Jan 6, 2018 08:56 PM
ron reece
Southern California Area
Oct 7, 2015 01:11 PM
Bubbajones_ya
Aug 31, 2015 12:02 PM
Thornburg
Aug 27, 2015 08:28 PM
