Fuel Injectors... In NEED or for TRADE!
Old Dec 17, 2008 | 03:49 PM
VA91Z28's Avatar
I have a 91 Z28 TPI that had a 305 motor. Well, before I did the motor swap to a 355, my stock 19lb injectors went out and I wasn't ready to do the motor. So, in a rush and without thinking, I got new fuel injectors which are 21lb. They worked great in the 305 and are alright in the 355 but my cam is a bit much for them. So, I really need a set of injectors preferably between 26 and 32lbs. My Venom 21lbs are in great condition, have about 1000 miles on them, are about half a year old, and I am willing to trade...
Thanks!
Patrick
Old Dec 17, 2008 | 08:19 PM
southbay08's Avatar
Re: Fuel Injectors... In NEED or for TRADE!
Hi Patrick, we would be more than happy to help you out. We have:
27lb bosch design lll
30lb bosch
32lb "modified" bosch design lll's
If you are interested we are offering a 10% discount on all products and services. If you go to our website www.southbayfuelinjectors.com
just type in discount code: N665 at checkout.
Hope this will be helpful.
Old Dec 20, 2008 | 07:04 PM
1991CamaroRslow's Avatar
Car: 1991 L03 700r4 RS
Engine: 1987 WS6 Trans AM Lb2
Transmission: Th350 red neck Performance 3k stall
Axle/Gears: 95 Mustang 8.8 built with 3.73s
Sell your Venoms and go with the generation 3 Bosch injectors like the LS1's came with.
Old Dec 21, 2008 | 09:22 PM
southbay08's Avatar
There has been great feedback on the design lll's. The 4 spray pattern provides more effiecient fuel atomization which will give better idle and acceleration over the standard injector.
Old Dec 21, 2008 | 09:53 PM
QuickStyle's Avatar
Car: 91 Z28
Engine: 383 SuperRam
Transmission: ProBuilt 700r4
Axle/Gears: G92 3.23
anything over a 24lb injector on your 350 is going to require you to tune the computer. 90-92 cars whether it be a 305 or 350 came with 21lb injectors stock. only the 89 and lower 305's got 19lb and 350's got 22lb. you can play with fuel injector sizes a little bit, but the stock computer can only compensate so much, so anything bigger than a 24lb injector is going to require a tune, it won't run right, and the tpi engines are super rich in power enrichment mode anyway, you don't need anymore fuel. i'd recommend staying with your 21lb injectors, unless you can give me some more detailed info on your engine.
Old Dec 22, 2008 | 08:48 AM
irocuroc's Avatar
Car: 89 iroc
Engine: l98
Transmission: tremec
even with 24's i would suggest a tune. on open loop its going to be way rich and on closed with a single o2 i don't thing the blm will correct the amount of fuel. One thing you don't want is bore wash on a older engine or for that matter any engine.. do it right.. select the injector you need and send the prom to PCM for less or another good mail order tuner and be done with it. You have some good money invested already.. don't skimp on the tune.
Frozer!!!
Jan 19, 2024 04:55 PM
AkDrifted
Aug 17, 2015 07:45 PM
Catcher55
Aug 15, 2015 07:08 PM
kyleb24
Aug 15, 2015 08:24 AM
