HELP Vortec/SLP runner injector PROBLEM!
Old Dec 27, 2008 | 09:18 PM
david068513's Avatar
Car: 1992 z28/1992 RS heritage edition
Engine: 350 tpi, 305 tbi
Transmission: 700R4,T5
Axle/Gears: G92
on the driver side. on the second runner one of the fuel injector won't clear the runner.I need to make this work by tomorrow. need ideas of what to do? anything?
Old Dec 27, 2008 | 09:33 PM
Axle/Gears: G92
Re: HELP Vortec/SLP runner injector PROBLEM!
Our problem was that the runner was forcing the injector upward and sideways. We didn't have the clearance we needed in that little sliver of a space between the injector and the fuel rail and then between the injector and the runner.
there's physically no room for the injector plug on #7 when the runner is installed. We tried everything we could think of, but we just couldn't get it to fit. It seems my only option is to grind material off the inside of the runner
Old Dec 27, 2008 | 10:12 PM
Axle/Gears: G92
anyone? need help soon..
Old Dec 27, 2008 | 11:45 PM
Shadygrady's Avatar
Car: 87 IROC Z
Engine: 5.7 L98 TPI
Transmission: 700r4,2500 stall
Axle/Gears: G80,10 bolt 3.42's
I`m about to put aTPIS bigmouth manifold and slp runners.I dont have an answer for you but I`ve been doing alot of searching and havnt seen this problem before.I would advise against grinding any material off the runner to get it to fit.Are you using stock injectors?You sure the runners are on the proper sides?
Old Dec 28, 2008 | 01:40 AM
1bad91Z's Avatar
Car: Faster
Engine: Than
Transmission: You!
Didn't have that problem at all with mine.......
Try switching the runners, passenger with driver side???..........
Old Dec 28, 2008 | 07:50 AM
irocuroc's Avatar
Car: 89 iroc
Engine: l98
Transmission: tremec
you have to have the runner backwards.. never had a issue with the injectors being to big.. what injectors are they.. show a pic of the fit problem.. don't grind
Old Dec 28, 2008 | 11:12 AM
Axle/Gears: G92
they arent backwards. The cold start was on the correct side.
Old Dec 28, 2008 | 01:44 PM
Shadygrady's Avatar
Car: 87 IROC Z
Engine: 5.7 L98 TPI
Then somethings probably not lined up right somewhere.
Old Dec 28, 2008 | 03:07 PM
Axle/Gears: G92
Well he compared the fuel rails and mine are bigger and wider they his l98 gta any ideas? Did they switch the size in those years?
Old Dec 28, 2008 | 03:28 PM
redrummer's Avatar
Car: '88 Trans Am GTA
Engine: 5.7L L98
Axle/Gears: 3.27 Aussie 9 Bolt
Hey David, nice job copy/pasting my PM to you!
Dork.
To all that have helped thus far:
We had the runners on the correct sides. I took a look at it again this morning after a good night's sleep and still couldn't figure it out. Like I said in my PM to David, the runner was actually forcing the #7 injector up and to the left.
David mentioned that someone somewhere mentioned something about them possibly being Corvette fuel rails and that being the case, they would be different from the stock Camaro/Firebird fuel rails. I don't know anything about that, but this morning I did notice that his fuel rails are different from the ones in my GTA in that they are noticeably wider.
I ended up putting his car back to stock for him this morning so he can at least drive it. He's all good now, just need to try and figure out this little installation issue before he tries it again.
And David, I really wouldn't recommend grinding down the runner. I was joking about that. Those runners I sold you have been ported so much I don't even know how thin those walls are. We could have cut a notch out, but I've never welded aluminum before. That might be your ultimate answer, unless you can find some stock fuel rails to replace yours with (assuming that's the problem).
Old Dec 28, 2008 | 03:50 PM
Axle/Gears: G92
Dork.
you expect me to re write everything you aready have? plus those were your post on GAFBA not the PM.
anyone got any ideas on my issue?
stalkier
Dec 6, 2015 11:25 PM
mdtoren
Aug 23, 2015 12:52 PM
justin57
Aug 20, 2015 07:05 PM
Bryan F
Aug 18, 2015 02:28 PM
mdtoren
Aug 16, 2015 05:45 PM
