how will a ported tpi respond to 10.5:1 or 11:1
Old Dec 28, 2008 | 12:57 AM
wanab03ss's Avatar
Car: 87 GTA
Engine: 385 sbc
Axle/Gears: 2.73 posi
I have a 355 with flat tops 6cc reliefs ,decked to .015 and a set of 53cc 601s I was thinking of putting on it with my tpi set up. Any ideas how it would respond... also the cam is comp 268h-10... I know the close lsa will make for a tough chip burn but I would be sending it out to pcm4less and theyll be doing the tune.
Old Dec 28, 2008 | 03:40 PM
1989GTATransAm's Avatar
Car: 1989 GTA
Engine: 369 TPI
Axle/Gears: 3.70 Nine Bolt
Re: how will a ported tpi respond to 10.5:1 or 11:1
Just fine as long as it does not ping. Are these iron or aluminum heads that you will be using?
Just fine as long as it does not ping. What are the 601 heads? Iron or aluminum?
Last edited by 1989GTATransAm; Dec 28, 2008 at 03:41 PM. Reason: Automerged Doublepost
Old Dec 28, 2008 | 04:08 PM
Air_Adam's Avatar
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
They are cast iron. I have a set on the shelf. Nice heads for a high compression small block.
Old Dec 28, 2008 | 04:53 PM
S105.7's Avatar
Car: '87 S10 Blazer & '91 RS
Engine: L98 & L03
Transmission: 700R4 & T5
Axle/Gears: 10 Bolt/3.73/3.42
Better get into PROM tuning. With that much compression, its gonna ping like crazy. Once it starts to ping, the ECM is gonna pull tons of timing, and then its gonna be a pig.
Old Dec 28, 2008 | 06:27 PM
Car: 1989 GTA
Engine: 369 TPI
Yep, to much compression for iron heads. I would not try for more than 9.5 in your situation. If you tried for 10.1:1 you would need your ducks in a row. Couple of things for openers. You would need a tight quench, a real efficient cold air intake and a big radiator to make sure you don't go over 180 degrees. Vizard has a list of about 10 items needed to run high compression and I only covered three.
Fast355
Dec 2, 2016 06:33 PM
LT1Formula
20
Nov 14, 2015 12:02 AM
Dialed_In
Aug 20, 2015 01:45 PM
Sanjay
Aug 12, 2015 03:41 PM
mx127
Aug 10, 2015 08:13 AM
