86 TPI doesn't have spark. What should I check?
Old Dec 28, 2008 | 06:03 PM
BrianI's Avatar
Car isn't firing and I'm not sure what I should check.
Old Dec 28, 2008 | 06:17 PM
TIMMYS89GTA's Avatar
Car: 81z-28,89gta,91z-28 03 1500
Engine: 355,L98vette tpi,327
Transmission: TH350/700R4/700r4/4l80E
Axle/Gears: 3;73/3;27/2;73/3;73
Re: 86 TPI doesn't have spark. What should I check?
I would first check the coil and then the ignition module in the dist.
Old Dec 28, 2008 | 06:19 PM
BrianI's Avatar
Will do. thanks
Old Dec 28, 2008 | 07:50 PM
DAVECS1's Avatar
Car: 91 GTA
Engine: 377ci
Axle/Gears: QP Ford 9" 3.70s
If that does not pan out look at the pick up coil in the distributor.
Old Dec 28, 2008 | 09:00 PM
87transGTA's Avatar
Car: 87 GTA
Engine: 350 Tune port
Transmission: 700r4,2500 stall
did you forget any wires or anything or even a ground or possibly a blown fuse?
maroe624
Apr 16, 2017 08:29 AM
Wade787b
Sep 29, 2015 01:15 PM
justin57
Aug 20, 2015 07:05 PM
Sanjay
Aug 12, 2015 03:41 PM
