Bad Vacuum Leak?
Old Dec 28, 2008 | 03:04 PM
85Iroc-Z's Avatar
Car: 85 Iroc-Z
Engine: 383 TPI Procharger D1SC
Transmission: TKO600
Axle/Gears: Strange S60 3.73
Bad Vacuum Leak?
My car has a real bad vacuum leak and I can't find where its coming from. The car will start but it will not idle. It sounds like it is coming from the drivers side. This happened after I just finished adjusting the valves, put an adjustable fuel pressure regulator on, and put new intake gaskets on. Where do you think this could be coming from?
Old Dec 28, 2008 | 04:04 PM
irocuroc's Avatar
Car: 89 iroc
Engine: l98
Transmission: tremec
Re: Bad Vacuum Leak?
check this out... the left and right lower runner gaskets are different but will bolt up to either side, if you put the wrong one on the wrong side you will have a bad vac leak like you describe. it will race too like 2200 rpm. I bet thats what you did.. also the cold start not sealed will leak vac
Old Dec 28, 2008 | 10:05 PM
85Iroc-Z's Avatar
Car: 85 Iroc-Z
It does sound like it is coming from the cold start injector. I'll check it out. I was able to get the car to idle now.
Old Dec 28, 2008 | 10:12 PM
sgt473's Avatar
Car: 87 Z28
Engine: LB9
Transmission: 4L60
Axle/Gears: 2:73
Spray a little carb cleaner where you hear the leak. The engine will rev when you hit the right spot. Just use short bursts be careful .hope it work for you.
Old Dec 28, 2008 | 10:22 PM
irocuroc's Avatar
Car: 89 iroc
Engine: l98
if its racing over 2000 don't waste your time with carb cleaner, it will just suck in.. if its under 2000 it will work// use smoke with engine off
Infested
May 22, 2018 11:56 PM
bamaboy0323
Sep 3, 2015 06:07 AM
FreeSpirit
Aug 29, 2015 05:47 PM
Bubbajones_ya
Aug 28, 2015 02:17 AM
