Fuel rail torque value?
Old Dec 28, 2008 | 06:20 PM
tpiselli's Avatar
Car: 83 T/A, 83 S.C., 86 S.C. & IROC
Engine: 305 CFI &TPI
Transmission: 4L60E, 700R4
Axle/Gears: 3.23, 2.73
I'm putting my fuel rail back together after tearing it down to clean it up and replace all of the o-rings but, I don't see a torque value for the bolts that hold the crossover tubes in place. I have an '86 service manual but couldn't find a value. Does anyone know what this might be? I don't want to over tighten anything. Also, do I need to use a thread locker for these as well?
Thanks,
Tony
Old Jan 3, 2009 | 11:58 AM
Vader's Avatar
Re: Fuel rail torque value?
40 in/lb, and LocTite 242 might be a good idea.
Old Jan 3, 2009 | 05:48 PM
tpiselli's Avatar
Hey Vader thanks for the information. Since I didn't find anything in the 5.0L section I looked in the 2.8L section and found a value. In the 1986 manual for the FUEL BLOACK AND SEAL (page 6E3-C-24) in the INSTALL AND CONNECT section it calls for 44 in. lbs which is what I used. It didn't mention any thread locker but, even though the fuel rail is back on the manifold, I haven't installed the pressure regulator yet so I have access to all the bolts and can easily go back and put some on.
Thanks again,
Tony
Andrew6.688
Dec 13, 2015 10:59 AM
stalkier
Dec 6, 2015 11:25 PM
sweet_87_iroc
Sep 25, 2015 10:01 PM
Armored91Camaro
Aug 12, 2015 09:41 AM
92projectcamaro
Aug 6, 2015 01:20 PM
