1990 - 1992 Speed Density Compression Ratio
Old Jan 4, 2009 | 03:17 PM
88TransAmFreak's Avatar
Car: 1971 Camaro
I had a quick question, My engine is a stock 82 Corvette engine that is 9.0:1 compression with a 1990 - 1992 TPI Speed Density set up on it.
My custom chip is based on a 1990 - 1992 Camaro 350 TPI automatic baseline. If I'm not mistaken the compression ratio is 9.5:1 on these engines.
Will this have an adverse affect on how my engine runs because of the compression differences?
Thanks!
Old Jan 4, 2009 | 06:03 PM
gearhead0384's Avatar
Car: 1989 Camaro IROC-Z
Engine: L98 350 TPI
Transmission: Built TH-700 R4 (Vilgilante 2800)
Axle/Gears: 9 bolt w/ PBR's
Re: 1990 - 1992 Speed Density Compression Ratio
1990-1992 350 TPI compresstion is 9.7:1.
Old Jan 4, 2009 | 06:09 PM
Car: 1971 Camaro
Even so, will that affect the fact that this set-up is on a engine with a 9.0:1 compression ratio?
Thanks!
Steve78LT
Feb 24, 2016 12:15 AM
beastin91rs
Oct 9, 2015 07:38 AM
Thornburg
Aug 27, 2015 08:28 PM
Keith5
Aug 27, 2015 04:37 PM
86Base
Aug 8, 2015 01:34 PM
