How to polish my runners
Old Jan 8, 2009 | 06:24 PM
SiCkRs's Avatar
Car: 91Z28
Engine: 5.7 ls1
Transmission: 4l60e
I have stock runners and want to polish them but i am thinking of hand sanding them but i heard they mess up
Old Jan 9, 2009 | 12:18 PM
ChoobinatoR's Avatar
Re: How to polish my runners
you're going to need different grits of sandpaper and there will be wet sanding taking place.
you will probably need a hand powered tool to use so you can buff and polish.
basically polishing just has to do with smoothing everything out, so you grind off the big impurities with rough sand paper, then you go smoother and smoother as time goes on.
takes the right equipment and chemicals to do the job right (looking good), and a lot of patience and time.
Old Jan 9, 2009 | 04:27 PM
SiCkRs's Avatar
Car: 91Z28
Engine: 5.7 ls1
Transmission: 4l60e
I polished my plenum with this things
  1. 3M Sandpaper.
    80, 120, 220, 320, 400, 600, 800, 1500 grit
  2. 3M marine aluminum restorer
  3. Mothers Aluminum Polish
  4. Polishing cloth
You think i could use this to polish my runners because the previous owner said he tried to polish them but they came out ugly so he painted them
Old Jan 9, 2009 | 06:07 PM
BC GTA's Avatar
Car: 1989 GTA
Engine: 5.0 TPI
Transmission: T-5 WC
Axle/Gears: Yukon 3.73
If the runners have scratches in them you could use successive degrees of fine sand paper as mentioned above. Removing the runners from the engine would facilitate this; however, this is a lot of work just to polish some parts.
If all you want to do is make them shine and the runners are either on or off the engine; then use some Mothers Aluminum Polish and a rag to rub the polish on with. Then use a buffing pad in your drill to make the runners shine.
Old Jan 9, 2009 | 06:24 PM
SiCkRs's Avatar
Car: 91Z28
Engine: 5.7 ls1
Transmission: 4l60e
I have them off right now because i am rebuilding my engine and i polished my plenum and now want to polish my runners altough they have paint on how can i take the paint off.
Old Jan 9, 2009 | 06:29 PM
SiCkRs's Avatar
Car: 91Z28
Engine: 5.7 ls1
Transmission: 4l60e
so if i just polish it with aluminum polish would it give it a shine
Old Jan 10, 2009 | 03:28 PM
BC GTA's Avatar
Car: 1989 GTA
Engine: 5.0 TPI
To remove paint I use a product called Poly Strippa by LePage’s. I have used this to remove automotive paint on valve covers and other parts. Make sure you read the instructions as this stuff is very caustic and will produce chemical burns to human skin. Consider wearing rubber gloves.
Try the Mothers polish on the runners combined with a high speed buffing. That will make them shine. If it is not to your satisfaction then redo with successively fine grit sand paper finished with Mothers again.
Old Jan 10, 2009 | 06:55 PM
SiCkRs's Avatar
Car: 91Z28
Engine: 5.7 ls1
Transmission: 4l60e
i will try with the grit but should i use all the ones that i used for the plenum i just wanted to know if they are aluminum because my uncle told me they ain't
Old Jan 10, 2009 | 07:23 PM
Stephen's Avatar
Car: 87 GTA
They are aluminum & a magnet will verify that.
Old Jan 10, 2009 | 07:40 PM
SiCkRs's Avatar
Car: 91Z28
Engine: 5.7 ls1
Transmission: 4l60e
So i will try with the 80, 120, 220, 320, 400, 600, 800, 1500 grit paper and then polish it by hand then i will find out how it comes out
Old Jan 10, 2009 | 08:17 PM
RED_DRAGON_85's Avatar
Car: 85 Camaro IROC
Engine: 5.7 TPI
Transmission: 700-R4
Axle/Gears: open rear, 3.42 gears
if they are stock as cast finish, then simply using aluminum polish will only make them shiny and bumpy as opposed to the normal dull and bumpy.
if you want them to look like polished aluminum should, you will need to first remove the sand pattern cast into the runners with sandpaper.
you probably dont need to start all the way at 80 grit.
i would start at 320 or so and work my may up.
then use mothers billet aluminum polish.
then clear them or they will tarnish in a heartbeat
Old Jan 11, 2009 | 02:20 PM
S105.7's Avatar
Car: '87 S10 Blazer & '91 RS
Engine: L98 & L03
Transmission: 700R4 & T5
Axle/Gears: 10 Bolt/3.73/3.42
Clear them, and they'll turn yellow. You will need to have them sealed with something along the lines of Zoop.
Old Jan 11, 2009 | 03:44 PM
SiCkRs's Avatar
Car: 91Z28
Engine: 5.7 ls1
Transmission: 4l60e
So what should i do to polish them
Old Jan 11, 2009 | 09:48 PM
Car: 85 Camaro IROC
Engine: 5.7 TPI
yep. forgot about the heat thing lol
Old Jan 12, 2009 | 05:23 PM
SiCkRs's Avatar
Car: 91Z28
Engine: 5.7 ls1
Transmission: 4l60e
If it turns yellow i could just get some steel wood no
Old Jan 12, 2009 | 05:58 PM
jstoltz's Avatar
Car: 1987 Iroc-z Convertible
they are talking about what you use to seal them after you polish them. you can polish them and have them clear powdercoated. eventually it will yellow though too. as far as polishing them start with 180 and go to 400 then polish with a dremel or get a drill buffer kit. they are akward to hold onto and try and polish though. good luck.
Old Jan 13, 2009 | 05:10 AM
89transam*pearl's Avatar
Car: 89 T/A
Engine: LB9
Transmission: W/C T-5
Axle/Gears: 10 bolt posi, 3.73 Richmond Gears
Do a search in the Tech Articles....theres a step by step walk through that will have those runners and plenum shining like mirrors....good luck and well worth the effort!
Old Jan 13, 2009 | 11:20 AM
SiCkRs's Avatar
Car: 91Z28
Engine: 5.7 ls1
Transmission: 4l60e
I did that with my plenum and it looks like a mirror should i do it with the runners too i just typed plenum polish in the search and the first one that is what i did should i do that.
Old Jan 13, 2009 | 12:31 PM
Car: 85 Camaro IROC
Engine: 5.7 TPI
yep.
about the clear, you dont really have to.
you will just have to break out the mothers every once in a while and put a finishing touch on it.
dont use steel wool
that will scratch the heck out of your mirror finish.
Old Jan 17, 2009 | 09:12 PM
old fart's Avatar
I've ported and polished a set of slp runners to replace the stock runners,( also polished) and would suggest using fine paper 200 -220 grit wet paper with a little WD-40, IF YOU JUST HAVE SAND PAPER. Lots of work though, a buffing wheel,compound and a bench grinder do a better,easier job though. Go easy on them though even a buffer wheel could heat them up enough to distort or even burn through them.
Old Jan 18, 2009 | 12:28 AM
SiCkRs's Avatar
Car: 91Z28
Engine: 5.7 ls1
Transmission: 4l60e
I polished them with sand paper and look nice
Old Jan 18, 2009 | 02:47 AM
BluFBdy's Avatar
Car: 89 Camaro RS
Engine: 355 SD TPI
Transmission: WCT5
Axle/Gears: 3.08 Posi
i used never dull on one side of mine and they turned out pretty well
makes since lol we tested it on galvanized steel on our shed and it had a mirror shine to it
Old Jan 18, 2009 | 06:17 PM
SiCkRs's Avatar
Car: 91Z28
Engine: 5.7 ls1
Transmission: 4l60e
I have just sold my tpi and everything for $800 and the guy was happy
Linson
Oct 24, 2025 02:00 PM
Bubbajones_ya
Oct 25, 2015 08:01 PM
bigjay89gta
Oct 15, 2015 08:04 AM
TheCardinal
Exterior Parts for Sale
Oct 1, 2015 07:40 PM
Royal_Z
Sep 30, 2015 08:45 PM
