Hotter spark plugs?
Old Jan 14, 2009 | 08:39 PM
IrocZ_85's Avatar
Hotter spark plugs?
My 85 IROC 5.0 TPI is out of commission for the next few weeks while I do some interior and engine work.
I am upgrading the ignition system with Accel parts (cap, rotor, coil, wires). Should I bump up the heat range on the plugs? If so, does anyone have suggestions? I did a search, but the discussions were more platinum related. My car sees a lot of city/stop and go traffic, just looking for some ideas.
I'm also adding an air foil and K&N filters. I already have a nice Flomaster exhaust with a Magnaflo cat.
Old Jan 14, 2009 | 09:15 PM
luvofjah's Avatar
Car: 91 Black Formula KR
Engine: 305 TPI R69/G92
Re: Hotter spark plugs?
Your engine is mostly stock, run the recommended range...
Raf
Old Jan 15, 2009 | 12:30 AM
marolife03's Avatar
Car: 85 Z28
Transmission: 700R-4
I too have an 85, & when I bought my car a couple of months I replaced every ignition part except the distributor. When it came time to buy the plugs i asked around, you know local shops & friends with f-bodies, & everyone recomended the stock range. My car is a daily driver with stop & go driving as well.
Old Jan 15, 2009 | 05:58 PM
IrocZ_85's Avatar
Thanks, thats what I wanted to know.
When buying the coil, does the color of the wiring on the coil matter, like red/white or red/yellow?
Old Jan 15, 2009 | 06:16 PM
2fast4love's Avatar
yes the wires do matter get the exact ones your taking off. as far as spark plugs a good hot plug would be r45ts delcos thats what i use on all my cars except for my 88 tpi iroc. they run fine on carb motors just my two cents
Bubbajones_ya
Jul 6, 2024 08:32 PM
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
db057
Apr 28, 2019 07:45 AM
Jlanz55
Sep 9, 2015 09:09 AM
89 formula TPI
Sep 7, 2015 11:06 AM
