Difference between TPI Intakes ?
Old Jan 15, 2009 | 03:52 PM
hzemall's Avatar
I bought a complete top TPI system off a friend that was build by Arizona Speed and Marine, it has the Accel DFI, and harness etc. It's a 87 + system.
I have a pre 86 block, but I also have a 85/86 intake, will everything from the 87+ bolt onto the older intake ? Wanted to avoid modifying the intake to fit the old heads if I didn't have to.
Thoughts ?
Old Jan 15, 2009 | 08:48 PM
birdtojag's Avatar
Car: 87 Firebird, 90 bird coming soon
Engine: 355 Chevy Vortec Heads TPI, LT1 inj
Axle/Gears: 2.77 posi 9-bolt
Re: Difference between TPI Intakes ?
You can use the older intake with the newer runners and plenum. Will not be any problems from that.
1992rs/ss
Jan 31, 2025 05:10 PM
masonta
Aug 31, 2015 10:14 PM
Sanjay
Aug 12, 2015 03:41 PM
Jake_92RS
Aug 11, 2015 10:39 AM
