diagnosing a dying car
Old Jan 18, 2009 | 07:13 PM
gurkgurkgurk's Avatar
Car: 86 Camaro iroc-z28
Axle/Gears: 3.42 Posi
after running into countless problems with the cooling system and a whole buncha of other crap. ive been lead to believe its my ignition system thats causing my car to die at a stop. the problem im having is that when i turn on the car, itll idle very good for about 20 minutes, sometimes alittle more, then it turns off. then it wont turn back on until i wait for another 5 to 10 minutes to pass by, then itll just turn off again. so i decided today to take apart the upper part of the distributor and see what i have under the distributor cap. the cap and rotor were replaced recently so they had little to no wear, however the coil seems to be alittle on the ugly side. now what i need is some tips on to which component of my ignition system could give me this problem. some have told me the pickup coil, some have told me the module others have told me the ignition coil. and since im on a real tight budget because this car has drained me of all my enthusiasm and money, i need to just find the one that is the culprit and replace it. heres some pics to let you know what im working on and what condition its in.
any input is greatly appreciated
and yes i know i have a flat
Old Jan 19, 2009 | 05:21 PM
85berlinetta2.8's Avatar
Car: IROC Z
Engine: 5.7
Re: diagnosing a dying car
when my pickup coil went on my berlinetta, it would stall at all speeds, even on the highway. sometimes not start. when my ignition coil went it just wouldnt start.
-hey isnt that the camaro from the hulk hogan movie suburban commando?
Old Jan 19, 2009 | 05:39 PM
305sbc's Avatar
Car: 1986 Irocz
Axle/Gears: 3.25:1
Are you thinking it's an ignition problem due to it failing a test for spark?
When it's cranking the plugs do not spark at all?
Old Jan 19, 2009 | 06:09 PM
well i went ahead and tested my coil at home with an ohmmeter and it failed. so i know for sure its dead now. im just not sure if anything else is bad either.
the problem i get is that itll turn on, die after a while, then not turn back on. i hope this fixes my car
what hulk hogan movie
theshackle
Mar 5, 2017 06:37 PM
Spyder_TheGamer
Dec 25, 2015 05:07 PM
Wade787b
Sep 29, 2015 01:15 PM
