any place oil can get in coolant BESIDES head gasket?
Car: 84 sport coupe
Engine: stock lg4
Axle/Gears: stock?
Ive got milkshake oil...and losing coolant. Any place i can check out before i pull the heads off? this is a 91 tpi 305. the engine has about 30k miles on it, jasper reman
Re: any place oil can get in coolant BESIDES head gasket?
Yes! on the top of my head, intake manifold. loosing coolant so you would have coolant going into the oil instead of oil going into the coolant, right?
are you losing any of this mixture or can you see the oil level rising significantly?
good luck bro
good luck bro
Car: 92 T/A 'vert
Engine: Mild .040 over L98 4 bolt mains
Transmission: Mostly stock 700R4, 2600 Vigilante
Axle/Gears: LS1 3.42
Yep. Intake gasket. Years ago I was sold head gaskets/valve job as I didn't know any better. Pressure test the cooling system and see what happens.
ambainb
Apr 25, 2016 09:21 PM
NinjaNife
Aug 23, 2015 11:49 AM
