305 (LB9) performance heads
Old Jan 26, 2009 | 11:43 PM
jbates346's Avatar
Does anybody know the best "performance" heads for a 305. I know, I know, theres not much. So far all i can find are the Worldcastings S/R Torquer 305. Are there any other heads that will fit? Thanks for any help.
Old Jan 26, 2009 | 11:45 PM
watajob's Avatar
Car: 92 T/A 'vert
Engine: Mild .040 over L98 4 bolt mains
Transmission: Mostly stock 700R4, 2600 Vigilante
Axle/Gears: LS1 3.42
Re: 305 (LB9) performance heads
I'm pretty sure I'm going with these: http://www.trickflow.com/egnsearch.a...8&autoview=sku Only a few bucks more than the World heads.
Old Jan 26, 2009 | 11:50 PM
jbates346's Avatar
Those looks awesome! About how much do they run? Has anybody tried these? I don't see if there CARB EO legal. Stupid California!
Old Jan 27, 2009 | 12:09 AM
watajob's Avatar
Car: 92 T/A 'vert
About $1200 at Summit. $100 more than the World heads. Don't know about the E.O. thing. Send 'em an email. They'll get back to you.
Old Jan 27, 2009 | 10:01 AM
flaming-ford's Avatar
Car: 89 iroc-z
Engine: 305tpi
Transmission: wc-t5
Axle/Gears: 10 bolt 3.08 posi (4 now)
wow i didnt know they were that expensive i'd personally run l98 aluminum or 113 casting or zz4 heads whatever you want to call them, a good set of 113s can be head for like 600 as opposed to your 1200 and probably flow as well......
just my 2 cents
Old Jan 27, 2009 | 01:24 PM
BC GTA's Avatar
Car: 1989 GTA
Engine: 5.0 TPI
Transmission: T-5 WC
Axle/Gears: Yukon 3.73
The following post will give you all the information I found when researching 305 heads for a TPI set up:
https://www.thirdgen.org/forums/tpi/...tml?highlight=
Since I wrote that post I discovered there is a GM Vortec head for the 305 engine. Some of these heads require the use of a different intake base manifold. Some require external routing of the EGR passage. These factors will add to the cost of such a project.
The “best” head depends on what you want with regards to torque and horsepower at different RPM’s, what other modifications you have done, what other modifications you plan on doing and your budget.
Other head considerations are compression ratio especially when using aluminum heads and maximum valve lift if you have or are intending to install a cam or higher ratio rockers.
All these and other factors have been discussed in detail on several recent posts just waiting for you to search and find it.
Old Jan 29, 2009 | 07:32 AM
FormulaL98's Avatar
Car: 88 Formula, 72 Nova, 68 Chevelle
Engine: L98, mild 350, L79 327
Transmission: 700R4, M20, M20
Axle/Gears: 9b 327,10b 373, 12b 331
Personally I would go with a aluminum set of vette L98 heads (as they are already 58cc) and the only other thing you would have to change is over the egr (search vette egr on here). probably going to be the most cost effective way of swappoing heads on a 305. Just my 2 cents, I just couldnt justify spending 1200 bucks on heads for an engine that will forever be held back by valve shrouding due to the tiny bore size.
Old Jan 30, 2009 | 12:32 PM
BC GTA's Avatar
Car: 1989 GTA
Engine: 5.0 TPI
When using aluminum heads you may want to research the effects of heat transfer and that effect on combustion, power production, compression ratio and combustion chamber size. The 305 TPI engines came with cast iron heads with a 58cc combustion chamber and 9.3:1 compression ratio. If you use aluminum heads it has been recommended in car journals that you need to increase the compression ratio by at least one full percentage point i.e. up to 10.3:1. Consequently, for aluminum heads you will need something less than a 58cc combustion chamber. This could be achieved by milling the aluminum heads, but would result in added cost to this project.
Old Jan 30, 2009 | 12:46 PM
FormulaL98's Avatar
This is true, but not really a necessary step if you dont wanna spend the cash on more machine work. Your engine will be fine without bumping compression or a thinner head gasket can also boost compression and wouldnt cost much. Just something to consider i suppose
The reason why you can run a higher static compression with aluminum heads is that the material has a higher rate of thermal conductivity (lets more heat out) then cast iron, keeping the chamber cooler and allowing for more compression/more timing etc.
Old Feb 10, 2009 | 02:16 PM
SilentBobZ28's Avatar
Car: 2014 2SS/RS
Engine: LS3
Transmission: TR6060
Axle/Gears: 3.55
Edelbrock makes an excellent replacement head for the 305 lb9 or lo3 engines. It is part number 60859. It's a 60cc combustion chamber. Has 165cc runners to keep up the velocity needed for the smaller ci engines. Chevy High performance did a buildup with these heads on one. It gave significant gains.
They were also paired with the cam specific for these heads, and the edlebrock manifold. As I remember they picked up over a second in the quarter mile. However, retained fuel efficiency, dependability, and was still smog legal.
Last edited by SilentBobZ28; Feb 10, 2009 at 02:27 PM. Reason: wrote wrong part number
Old Feb 10, 2009 | 03:29 PM
BC GTA's Avatar
Car: 1989 GTA
Engine: 5.0 TPI
I contacted Professor Overdrive at Summit Racing on this issue of aluminum heads and heat transfer which provide the following response:
“It is true that an iron head will make more power than an equal aluminum head, because of heat, I have not seen anywhere that shows a " 1:1" ratio like that. I don't think you would see enough difference to notice it, except on a dyno. I wouldn't worry about it much.”
I suppose the higher flows and lower weight of these heads would offset any HP loss due to heat transfer from aluminum heads.
Do you have a link to the Chevy High Perfomance article.
Old Feb 10, 2009 | 06:44 PM
Car: 2014 2SS/RS
Engine: LS3
Axle/Gears: 3.55
I found this link to an 84 build up of a L69 http://www.chevyhiperformance.com/te...der_heads.html. I can't find the one of the lb9 build. If I can find the magazine i will scan it.
Jake_92RS
Jan 28, 2020 10:37 PM
gta90
Sep 15, 2015 04:00 PM
theurge
Aug 21, 2015 12:46 PM
kyleb24
Aug 15, 2015 08:24 AM
