TPI 383 Stroker
Old Feb 2, 2009 | 11:19 AM
Aarons92Maro's Avatar
Car: 1992 Camaro RS & 1994 Mazda 626
Engine: 305 TBI V8 / 2.0 4-cyl.
Transmission: 700R4 / I have no idea
Axle/Gears: Stock 2.73 / I don't know
TPI 383 Stroker
Which TPI unit do I need for a 383 stroker motor? Do I need one from an L98 5.7? Will the LB9 system work?
Old Feb 2, 2009 | 11:43 AM
David 91RS/Z28's Avatar
Re: TPI 383 Stroker
You might want to find a book on TPI. The factory intakes are the same b/w the 305 and 350 engines, but you don't want a factory intake on top of a 383. You will need a complete aftermarket system. If your converting from TBI, just purchase a whole Holley StealthRam kit which includes the complete intake, TB, sensors, fuel pump, puter., etc.... Good luck!
Old Feb 2, 2009 | 01:43 PM
Russ-So Cal's Avatar
Re: TPI 383 Stroker
It depends on the smog laws in Wisconsin. If you don't have any smog testing or just a tail pipe reading, just get one that will breathe well. If you need to be concerned with any more restrictive smog laws, you will need to take that into consideration. What kind of engine are you building? How stock appearing do you want the car to look? You might need to put an after market hood on the car to gain clearance for a stealth ram. I think the HSR will tend to make hp at higher rpms, but you might lose too much torque down low. The HSR is illegal for the street in So Cal so I have never seen one in action. For better low end, the First injection system might be a good choice. If you are looking to build a good system on a restricted budget; and you don't have any tpi parts yet, you could use a First base and runners with a ported stock plenum and stock fuel rails. The size injectors you need will depend on how many rpms/how much hp you are going to make.
Old Feb 2, 2009 | 02:40 PM
TA's Avatar
TA
Car: '88 GTA, 90 Formula
Engine: 5.7 TPI, fed growth hormones
Transmission: 700r4 4u2?
Axle/Gears: 9bolt
Re: TPI 383 Stroker
These guys are right: Apart from the injector ratings and tune, the 305 and 350 TPI systems are interchangable, and both will choke your 383 down severely.
I've heard rumors that the Holley Stealth Ram now can be had with provisions for an EGR, but I have not seen one. That would be the best bet, but you'll need custom tuning n matter what you do.
TA
Old Feb 2, 2009 | 03:13 PM
gurkgurkgurk's Avatar
Car: 86 Camaro iroc-z28
Axle/Gears: 3.42 Posi
Re: TPI 383 Stroker
what about a ported tpi system?
mhatfield 14
Oct 24, 2015 07:48 AM
Reddeath210
Oct 6, 2015 08:20 AM
Mickeyruder
Sep 2, 2015 02:45 PM
86White_T/A305
Aug 17, 2015 12:16 AM
Sanjay
Aug 12, 2015 03:41 PM
