AC and air pump deleted, Can tensioner be deleted?
Old Feb 7, 2009 | 12:26 PM
airbrushguy's Avatar
I deleted the tensioner as well and now the battery keeps going dead. Is it impossible to tighten the serp belt so it doesn't slip on the alt. without a tensioner? ('87 TPI )
Old Feb 7, 2009 | 01:22 PM
AaronIROCZ's Avatar
Moderator/TGO Supporter
Re: AC and air pump deleted, Can tensioner be deleted?
More than likely not. The tensioner also compensates for belt stretch.
Old Feb 7, 2009 | 01:25 PM
305sbc's Avatar
Car: 1986 Irocz
Axle/Gears: 3.25:1
I've done it but it requires some modification to the bracket holding the alternator so it will have some adjustment. You'll need about an inch of adjustment and it will probably still be tough to get the belt on & off - but not impossible.
Old Feb 7, 2009 | 01:34 PM
Any pics or further comments?
Old Feb 9, 2009 | 07:27 PM
TTT
Old Feb 9, 2009 | 09:17 PM
305sbc's Avatar
Car: 1986 Irocz
Axle/Gears: 3.25:1
I have no pics. I only ran that way for 1 - 2 years, then switched to v-belts.
You would have to slot one of the bolt holes ( in the bracket ) into a curved shape.
If your bracket doesn't allow, then look for a different bracket in a salvage yard.
If your bracket is one large piece for multiple accessories then you may have to cut out the part for the alternator and use something different if unable to slot a hole for adjustment.
evilstuie
Jan 9, 2020 08:29 PM
Infested
May 22, 2018 11:56 PM
actionj
Carburetors
Aug 16, 2015 09:51 AM
mcquigg
Aug 13, 2015 02:26 PM
drathaar907
Aug 6, 2015 04:20 PM
