vortec tpi intake
Old Feb 14, 2009 | 12:43 AM
zealand's Avatar
Car: 1987 formula firebird
Transmission: t5
vortec tpi intake
I have an 305 and I want to get 350 vortec heads. I was wondering where I can find the cheapest intake that will fit. and I was wondering about headers that will work too.
Old Feb 14, 2009 | 11:26 AM
Russ-So Cal's Avatar
Re: vortec tpi intake
Scoggin-Dicky commissioned Edelbrock to build a Vortec base for tpi. That is the only base on the market that will work with Vortec heads.
Old Feb 14, 2009 | 03:53 PM
watman02's Avatar
Car: 91 Z28
Engine: LB9
Transmission: 5 speed
Axle/Gears: 3.73 limited slip stock
TPIS also makes a vortec intake
Old Feb 14, 2009 | 06:59 PM
Abubaca's Avatar
I think the TPIS intake is actually the Edelbrock piece with TPIS stamped into it.
Old Feb 14, 2009 | 09:45 PM
I think you would be wise to read the thread "Super Vortec tpi base" by Jerry Who before investing in a set of Vortec heads. Vortec heads may be cheap, but they need a lot of work to handle the sort of lift you want in a performance engine, and then the amount of work needed to get the base to flow decent numbers will run the price up considerably. I think it would be a lot less expensive to get almost any of the aftermarket heads designed for tpi on L98 motors than to try to do all of the work needed to make the Vortecs work, unless you are like Jerry with a heliarc machine and complete machine shop in your garage.
1992rs/ss
Jan 31, 2025 05:10 PM
Fast355
Dec 2, 2016 06:33 PM
LT1Formula
20
Nov 14, 2015 12:02 AM
theurge
Aug 21, 2015 12:46 PM
Sanjay
Aug 12, 2015 03:41 PM
