Stealth ram tpi uprade
Car: 1986 Trans am-Firebird
Transmission: Stock
on summint the holley stealth ram tpi upgrade do you need to buy the fuel rail that is an option to run the stealth ram on an older motor?
Car: 92 rs
Engine: 355 stealth ram, dart heads, S480
Transmission: 4L80E
Re: Stealth ram tpi uprade
yeah you have to get the fuel rails for the stealth ram...check out stealthram.com, has alot of good swap info. I did mine about a year ago....best move i've made on it so far
Transmission: Stock
Aftermarket Fuel Rail RequiredNoBase FinishNaturalBase MaterialAluminumBasic Operating RPM RangeIdle-6,000EGRNoEngine Block StyleStock/OEM standard deckFuel Rails IncludedNoInjection StyleMulti-portInjectors IncludedNoIntake Section IncludedCompleteNotesHolley Twin 58mm throttle body or stock Chevy LT1 throttle body required. Upper to lower intake gasket provided.Plenum FinishNaturalPlenum MaterialAluminumQuantitySold as a kit.Runners IncludedYesRunners RemovableYesSupplemental Bosses Cast-InNoSupplemental Bosses MachinedNoThrottle Body IncludedNo
i found that on summit and it says no aftermarket fuel rail is neededn and i was wondering is that vortec compatable? or do you need to buy one in vortec compatable form
Car: 87 GTA
Engine: 385 sbc
Axle/Gears: 2.73 posi
you haveto buy the vortec compatabile one, is not a holley though its a Weiand which is made by Holley so theres no difference
9192camaro
16
Feb 3, 2019 12:21 AM
L98GTA87
Aug 11, 2015 06:55 PM
