Is there a Test for the MAF sensor?
Old Feb 15, 2009 | 07:18 AM
Slowridr's Avatar
Car: 1987 GTA Vert & 1991 GTA 5 Speed
Engine: 87 GTA-L98 91 GTA LB9
Transmission: GTA-700R4 & GTA T5
Is my only option to change this thing out to see if its indeed my problem?
Old Feb 15, 2009 | 04:20 PM
paulo57509's Avatar
Car: '87 IROC
Engine: LB9
Transmission: TH700R4
Re: Is there a Test for the MAF sensor?
Perhaps unplugging it and then road testing will isolate your problem. Unplugging it will cause the CEL to come on and I would think that the ECM would go into some kind of limp-home mode and stop reading inputs from the MAF (essentially by-passing it).
Old Feb 15, 2009 | 05:15 PM
Slowridr's Avatar
I did just that. At first the car ran very rich (maybe 1-2 minutes) Wow what a mean loopy idle like a hot cam. I raced the engine and it began to get the correct fuel mixture. Still this thing really sounds liked its really built up. Maybe I should put a clip on here and let you guys hear it and tell me what you think.
This is not the original engine, this engine was part of the package when I bought the car. Could it have possibly been rebuilt and I just need to get a new prom. I could be totally off base here but just a guess.
Basically it sputters when you put it under load. You stall it or cut it off then crank it back up and it runs for a little while like nothing happened.
I am taking it to a hot rod shop next week where they are use to trouble shooting unique situations, wiring and the like.
Id like to know what you all think though.
It has given me a code 23, ive changed the fuel pump, ignition control module, and fuel filter. The MAT sensor is not pluged in. I cant find where it is suppose to plug
GTAman
Sep 21, 2015 09:57 AM
Logan Bryant
Aug 27, 2015 11:52 AM
soarestransam
Aug 24, 2015 08:15 AM
Bert87
Aug 23, 2015 03:50 PM
