5.7 needs power
Old Feb 12, 2009 | 06:53 PM
rolly92cam's Avatar
5.7 needs power
so i just go a 5.7 z28 tpi, it has headers, shift kit, an new drag radials, but it hit a 14.6 at the track what can i put to give it some more power.
Old Feb 12, 2009 | 07:01 PM
irocinblue89's Avatar
Car: 89 iroc
Engine: zz383/compcam/gmpp intake/holley770
Transmission: 700r4 w/all the goodies
Axle/Gears: 4th gen 3:23w/powertrax
Re: 5.7 needs power
What gears do you have in the rear?
Old Feb 12, 2009 | 11:10 PM
IROCtheThird's Avatar
Car: '89 IROC-Z
Engine: LSx
Re: 5.7 needs power
You stole the words out of my mouth, if its an original 350 car they usually had BW 9 bolts with 2.77's. If thats the case throw a 3.45 or 3.42 back there and you will notice a big difference. Other than that, the usuall, cam, port work, better heads, tune, etc etc.
Old Feb 13, 2009 | 01:18 AM
rolly92cam's Avatar
Re: 5.7 needs power
stock gears, my friend is selling me some 3.73 but they tell they wont work the same as some 3.45, an the same guy has a lt4 hot cam for sell. what size of heads should i go with, an i thought u can tune tpi computer that well,
Old Feb 13, 2009 | 12:37 PM
Car: '89 IROC-Z
Engine: LSx
Re: 5.7 needs power
3.73's might be a little to much, 3.45's or 3.42's will work good. As far as heads, it depends on what your looking for, stock heads with some port work seem to work pretty good, as far as aftermarket goes, its endless. Your computer can be tuned just fine.
Old Feb 13, 2009 | 01:31 PM
rolly92cam's Avatar
Re: 5.7 needs power
3.45s it is, im looking for a 13 second car with out noz ( had noz on my old iroc an mest up my engine bad) but i did hit a 13.4 with it..thanks man
Old Feb 13, 2009 | 05:50 PM
Car: 89 iroc
Re: 5.7 needs power
I am doing my 89 iroc because of the same thing. Would not get out of it's own way. My problem was the gears. (2.77) I ran 14.2. You are in the ballpark. Irocz30589 is correct start with the rear gearing and move up. Suspension is very important also. (1st or 2nd mod) You want the energy you create to go through the tires to the track not into the suspension. Good luck and keep us posted.
Old Feb 14, 2009 | 12:40 PM
Car: '89 IROC-Z
Engine: LSx
Re: 5.7 needs power
13 seconds is very doable with out an power adders, mid-high 12's are also.
Old Feb 15, 2009 | 08:16 PM
rolly92cam's Avatar
Re: 5.7 needs power
thanks guys just ordered the underdrive pully set, a mild cam, an 3.45..ill keep u guys posted of how it go's
stalkier
Dec 6, 2015 11:25 PM
z28addict8490
Sep 5, 2015 03:56 PM
pimprs
Aug 24, 2015 11:20 PM
sailtexas186548
Aug 24, 2015 10:11 PM
stalkier
Aug 21, 2015 01:54 AM
