Going with 350 HO vortec instead of 305
Old Feb 16, 2009 | 03:40 PM
joshuamillerfd's Avatar
Car: 89 Iroc conv. & 03 Avalanche Z71
Engine: 5.0 TPI
I have decided to go with the GM performance 350 HO vortec create engine to be able to keep a TPI system on my 89 conv. Iroc. Along with TPI vortec intake, High-flo runners, and 58 mm throttle body. I am considering buying a turn-key engine and selling the carb and intake off of it so everything on the engine is new. Will everything else on the turn-key engine work with the TPI setup? Is there anything additional I will need for this setup? New fuel injectors? Chip/programmer? Ignition? My only other question is what headers are best/cheapest w/o smog setup?
Old Feb 16, 2009 | 05:07 PM
kcallais's Avatar
Car: 1985 Z28
Axle/Gears: garbage 2.73
Re: Going with 350 HO vortec instead of 305
You'll need slightly larger injectors and a new prom burned.
MustangBeater20
Oct 29, 2022 09:20 PM
Jake_92RS
Jan 28, 2020 10:37 PM
84z96L31vortec
Aug 20, 2017 12:16 AM
Fast355
Dec 2, 2016 06:33 PM
st.evel07
Aug 13, 2015 06:15 PM
