Fuel pressure problem. please help
Old Feb 19, 2009 | 10:10 PM
kurtass16's Avatar
i have a 1985 Chevy camaro iroc z that has a 5.7 tpi swapped in from a 85 corvette. after running for about an hour the car sputters and runs like **** and stalls out. if i get out and put my fuel pressure tester on the bleed valve im getting 24psi !?!? i have a new fuel filter, and high flow fuel pump from summit. i ran out of gas one time. could that have cooked my fuel pump for good??
Old Feb 20, 2009 | 04:37 PM
george 88gta's Avatar
Re: Fuel pressure problem. please help
No fuel could have damaged the pump, the fuel is used to cool the pump. I would check the fuel pressure regulator before I jumped back in to the fuel pump. Also, its possible that when the tank ran dry, you sucked up some debris and damaged the pump or clogged the filter. The regulator is easier to check, so that is where I would start.
Old Feb 20, 2009 | 10:41 PM
birdtojag's Avatar
Car: 87 Firebird, 90 bird coming soon
Engine: 355 Chevy Vortec Heads TPI, LT1 inj
Axle/Gears: 2.77 posi 9-bolt
Also bleed off the residual pressure and recheck it. If it is still at 24 psi, clamp off the hose for the return line and recheck pressure again (re-prime it). If it goes up (usually by a lot), the pressure regulator is definately bad. Check that and report back.
Old Feb 21, 2009 | 08:27 AM
Viprklr's Avatar
Car: 92 GTA/ 00 TA
Engine: 383/350
Transmission: 700R4/T-56
Never clamp it off completely.
The proper way to test is to give a continuous 12 volts to the pump.
Watch your fuel pressure.
Slowly pinch your return line.
Watch the pressure go up.
Do NOT bring the pressure over 65psi. The stock regulator is only rated for 65. Anything above that and you could destroy it.
This test only tests the output of the fuel pump. There is no actual test for a regulator besides seeing if there's fuel in the vacuum line. Only tests that eliminate everything else.
Old Feb 24, 2009 | 08:54 PM
customirocz's Avatar
Car: 86 Iroc-z
Engine: worked 350tpi
Transmission: built 700r4
Axle/Gears: auburn pos 4-10
Just a thought did you happen to prime the new fuel pump before installing it?If not i have seen them go bad from installing dry with no gas in the pump, it could be bad.
Old Feb 27, 2009 | 08:58 PM
teamstream's Avatar
Car: 91 Purple Z28
Engine: 5.7 TPI
Transmission: 700 R4
do you prime a pump by just turning the key forward a couple times with a guage hooked up? my 91z would only get about 20psi so im in the process of changing the pump. hope it does the trick!
Old Mar 1, 2009 | 06:02 AM
Viprklr's Avatar
Car: 92 GTA/ 00 TA
Engine: 383/350
You apply 12v to the fuel pump test port. It should be the female end of a spade connector located under your hood. It'll be close to the firewall on either the drivers or passengers side.
92camaroJoe
Jul 29, 2023 07:57 PM
R3500
Aug 17, 2015 12:16 PM
wayshegoes
Aug 17, 2015 12:00 PM
92camaroJoe
Aug 13, 2015 06:07 AM
Kaweh
Aug 9, 2015 02:54 PM
