Tpi intake manifold doesn't fit
Old Mar 3, 2009 | 02:29 PM
LouStugots's Avatar
Car: 2006 VW Jetta GLi
Engine: 2.0t
Ive been putting together a 350 tpi system and just got a set of procomp 3003a heads. when i went to install the tpi intake manifold it was about an inch to narrow. When i tried to line up the original manifold that came off this same block it was the same thing, so obviously the heads require a different size manifold but what? am i dealing with vortec style heads here, i have no idea what i need to be shopping for. does any one know of any adapter plates?
Old Mar 6, 2009 | 12:27 AM
ModPog84z28's Avatar
Car: 1989 Camaro RS
Engine: 496 BBC
Transmission: T-56 6 speed
Axle/Gears: 4.11 posi
Re: Tpi intake manifold doesn't fit
kinda sounds like your deck height is off :S might be able to have a machine shop fab you some plates, but it prolly wont be cheap or perform well. are you sure your heads are 23 degree and not 18 degree circle track heads? some pics would definitely help with the diagnosis.
Old Jul 24, 2014 | 01:08 AM
thebandit50187's Avatar
Car: 92 Trans Am, 87 Formula
Engine: 305 soon to be TBI, 91 305 TPI swap
Axle/Gears: 10 bolt
there are a few factors that could be the issue here. first what year is the TPI intake manifold. 87-92 model years have centerbolt valve covers and have 4 bolts at different angles in the center of the base and theres an easy fix to making these work, just use a gasket lined up the ports and other boltholes and drill at the same angle all the other holes are at. other factors are the heads have been milled or the block has been decked the fix there is take the base to the machine shop and have it milled to fit the engine. lastly i saw pro comps 3003 heads and they have a multi pattern on them and its early style and vortec style and i dont know if im 100% right but i believe you may have to get a vortec base like you would if it was a fastburn head.
1992rs/ss
Jan 31, 2025 05:10 PM
86IROC112
Aug 17, 2015 02:00 PM
st.evel07
Aug 13, 2015 06:15 PM
Sanjay
Aug 12, 2015 03:41 PM
Jake_92RS
Aug 11, 2015 10:39 AM
