Could it be the prom ?
Old Mar 3, 2009 | 10:14 PM
machzee's Avatar
Been posting like mad way way over rich condition , The prom is from a 90 vette and modded , the motor is a new 350 with 2.02/1.60 64 cc heads steel,
This is the cam card Lift: Intake @Cam 2800 @Valve 4420 All Lifts are based on zero lash and theoretical rocker arm ratios. Exhaust @ Cam 2947 @Valve 450
Rocker Arm Ratio 1.6
Cam Timing: TAPPET @.050
Lift: Opens Closes Max Lift Duration
Intake (5) ATDC 29 ABDC 107 204 °
Exhaust 44 BBDC (10) BTDC 117 214
Cam Timing: TAPPET @---
Lift: Opens Closes ADV Duration
Intake --- --- 270 °
Exhaust --- --- 280 °
The prom does not use vss,vats,egr,lockup etc.. was burned cutom before
I fuel pressure falls of very fast like 48 at key on to 12 lbs 45 seconds later
should i get a prom made ?
This motor is in a 2002 wrangler with 4.10 gears
Linson
Oct 24, 2025 02:00 PM
89-IROCZ-5.0TPI
Feb 22, 2022 09:26 PM
dusterbd
Sep 29, 2015 08:40 AM
BLK87Z
Sep 18, 2015 11:29 PM
Winchester1094
Sep 15, 2015 09:48 AM
