Air tool for changing valve seals
Old Mar 5, 2009 | 05:42 PM
TORN's Avatar
Car: 88 IROC-Z
Engine: 6.9L TPI(FIRST) 421ci
Axle/Gears: Ford 9" Eaton truetrac 3.50
Anyone want to let me borrow there air tool that threads into the heads so I can change my valve seals. If I have to I will make one but I thought I would see if anyone made one and now its just sitting and waiting for me to use.
Old Mar 5, 2009 | 07:36 PM
UNCLE TOM's Avatar
Car: 91 R/S , 89 dodge p/u
Engine: L31 GM crate re-cammed , 318
Transmission: T-5 , 4 speed auto
Axle/Gears: 3.42 , ?
Re: Air tool for changing valve guildes
i'm not sure what your asking for . are you changing valve guides or valve seals ? if it's valve guides , let a machine shop do it . if its valve seals & you want to put air press. against the valves , check your local parts store . most will have fittings to do it . good luck .
Old Mar 5, 2009 | 07:46 PM
TORN's Avatar
Car: 88 IROC-Z
Opps my bad. Yea valve seals.
1992 Trans Am
May 10, 2023 07:19 PM
Exxon Limited
Camaros Wanted
22
Dec 21, 2015 10:36 PM
gta90
Sep 15, 2015 04:00 PM
Zachattack0925
Aug 12, 2015 09:54 PM
Zachattack0925
Aug 12, 2015 09:52 PM
