replacing stock runners/intake/tb
Old Mar 6, 2009 | 04:25 PM
89mulletbird's Avatar
Car: 89 GTA
Engine: 6.0L Procharged
Axle/Gears: 4.10
I am having some vacuum leak problems with my stock tpi setup so I want to buy an aftermarket intake/runners/throttle body to put on my stock '87 305 TPI. Any suggestions to the least expensive aftermarket approach?
Old Mar 6, 2009 | 06:06 PM
Kevin91Z's Avatar
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
Re: replacing stock runners/intake/tb
Edelbrock TPI intake manifold is the least expensive, unless you can find an Accel or TPIS one used.
Runners is up to you, anything you can find new or used, Accel, Edelbrock, SLP, AS&M.
Same with the throttle body, whatever you can find. Just make sure it comes with an air foil.
customblackbird
Aug 15, 2021 10:16 PM
NBrehm
Aug 25, 2015 11:49 PM
TheExaminer
Aug 25, 2015 07:34 PM
marcusaw
Aug 10, 2015 08:13 AM
Leggman1
Aug 6, 2015 04:15 AM
