trouble with the tpi
Old Mar 6, 2009 | 10:57 PM
jugheads88gta's Avatar
Car: 89 camaro
Engine: 68-454,87-nothing yet,88gta-305 tpi
Transmission: stock 700r4
Axle/Gears: borg warner 9-bolt/3:27 gears
to start off i bought a cam for my 88 t/a gta 305 tpi. i didnt have enought power. so i go to do the install not knowing i had to take the lifters out.so i get round to going to take the lintake and whole tpi system off and damn i must have broke every vac line there was and the heater controll valve and this hole time every thing that has to do with with the smog system is in the way so i live in florida and we dont have emissions down here so bye bye to all the smog lins and crap so i get the intake off and find a whole hand full of sludge under my intake just chilling on my lifters and push rods so i clean that put get the old cam out get the new cam in and the timing chain does not fit on my timing gear on my new cam!!!!! so i tried and use the stock gear and it does not fit on the cam so what do i do?
Old Mar 8, 2009 | 04:59 PM
Car: 89 camaro
Re: trouble with the tpi
update i have got the cam in i got a new timimg chain and timing grears and i got all of that on and my crank bolt some how got messed up and i cant find anothe one.
Old Mar 9, 2009 | 01:43 AM
Kevin91Z's Avatar
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
Your 88 GTA should have a roller cam. Did you buy a flat-tappet cam and that's why the timing chain didnt fit?
Second, its still a federal law that your emissions devices must remain on the car. Some time in the future, thanks to our current administration, you can look forward to mandatory smog checks across all 50 states.
Old Mar 10, 2009 | 04:36 PM
Car: 89 camaro
think i bought a 1st gen cam because the the thurst plat tht hold the cam in i had to make the center larger to fit over
evilstuie
Apr 14, 2016 08:52 PM
Bstrang6
Sep 8, 2015 04:29 PM
theurge
Aug 21, 2015 12:46 PM
Camarothatcould
Aug 20, 2015 08:49 AM
Sanjay
Aug 12, 2015 03:41 PM
