Passenger Bank Lean
Passenger Bank Lean
Passenger Bank is running way to lean, heats up 5x faster than the driver side and the car barely runs. injectors are good, fuel pressure is good, could a vacuum leak cause this or what would be the next thing to check?
Re: Passenger Bank Lean
bump! i take back the barely runs... the car runs but is not drivable... shakes pretty good when put into drive. it seems to idle fine at 900. car wont rev past 2500 like the computer is stopping the advance. i did a vacuum leak test and found nothing
sjorgens
Oct 1, 2015 07:54 PM
