Fuel or Computer problems???
Old Mar 14, 2009 | 12:46 AM
Z28 Rida's Avatar
Car: 92' Z28
Engine: 406
Axle/Gears: 3.23 Posi
To start off i have a 92 z28 with a 350 L98. It does have an aftermarket stereo. The other day I was driving and the car started to sputter on me then it died. When i tried to restart it it would fire up then die down right away I still have feul pressure at the rails but the car still wont start.Is there anyway my alternator would not be able to handle my stereo and running the car? Bad Computer? Any ideas???? Im very new to working on cars so any advice would be greatly appriciated. Thank you
Old Mar 15, 2009 | 03:03 AM
Z28 Rida's Avatar
Car: 92' Z28
Engine: 406
re: Fuel or Computer problems???
ttt!!!!!!!!! Really need help guys any advice would be great
Old Mar 15, 2009 | 08:14 AM
Viprklr's Avatar
Car: 92 GTA/ 00 TA
Engine: 383/350
Transmission: 700R4/T-56
If it starts and then dies...your alternator is fine.
Try starting it while holding the gas a bit.
Old Mar 15, 2009 | 05:20 PM
Ls2 GTO's Avatar
Car: 92 purple haze z03 z28
Engine: Lb9
Transmission: 5 speed
maybe fuel related , ever changed the fuel filter ? could be clogged . I would try that first , if it still does the same thing start checking fuel pressure to see if the fuel pump is good.
Old Mar 15, 2009 | 08:08 PM
badblackiroc's Avatar
Car: 88 IROC-Z
Engine: L98 350 Built
Transmission: Built 700R4
take your ignition module out of ur distributor and take it to advanced auto or autozone, they can test it to see if its bad. make them test it like 5 or 6 times, usally it will test good the first couple of times but after it starts to heat up it will start acting bad, or failing tests so to speak. but that would cause ur car to start and die. my camaro did the same thing. the longer id let it sit the longer it would stay started. i had my module tested and it took 7 tests for it to heat up and give errors.
Old Mar 16, 2009 | 06:19 PM
Z28 Rida's Avatar
Car: 92' Z28
Engine: 406
Re: Fuel or Computer problems???
Feul Filter is new and i have pressure from my feul pump and at the rails so i dont think its my pump or filter ill try and get that tested and see what it does. Thanks
Old Sep 12, 2009 | 08:38 PM
Slowridr's Avatar
Car: 1987 GTA Vert & 1991 GTA 5 Speed
Engine: 87 GTA-L98 91 GTA LB9
Transmission: GTA-700R4 & GTA T5
Did you ever fix your car?
Ghettobird52
Jul 5, 2024 11:18 PM
92camaroJoe
Jul 29, 2023 07:57 PM
9192camaro
16
Feb 3, 2019 12:21 AM
Infested
May 22, 2018 11:56 PM
92camaroJoe
Aug 13, 2015 06:07 AM
