iac valve
Car: IROC Z28
Engine: 5 litre 305
iac valve
ive been reading some old posts on iac valves and rough running, mines running rough at idle which is the iac valve? as i want to clean it, sorry probably a stupid question
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
Re: iac valve
Its the square plugged sensor on the passenger side of the throttle body, beneath the TPS sensor.
Car: IROC Z28
Engine: 5 litre 305
Re: iac valve
thanks ill have a look, cars running rough almost a miss on tick over but cars been sat years so im guessing fuels no good
Engine: 350 TBI W/all Ultimate TBI Mods
Transmission: 700R4 Stage 4
Axle/Gears: 9 Bolt 3.27
Re: iac valve
First thing is fresh fuel. Second thing is clean the injectors PROFESSIONALLY. If you want your car to run well it is best you send them off to have them professionally ultrasonically cleaned and flow tested.
Cleaning the IAC is as simple as removing it and spraying the heck out of it with carb cleaner, etc. New gaskets/o-rings etc are a MUST when a car is sitting for so long.
Oh and a new fuel filter, lol...
The above may not be your idle issue, but this is by far the first step with an older vehicle that has sat for so long.
Is this TPI or TBI? I assume TPI correct?
Car: IROC Z28
Engine: 5 litre 305
Re: iac valve
yep its tpi, ive just dropped another engine in it, as original seized. so it has all new gaskets, i bought the car not running a year ago and it had been off the road about a year then but had only done about 9 miles in about 5 years so im guessing fuel could be very old, im thinkin a good run and injector cleaner may help, just need to sort out my rear brakes
