High idle, timing questions.
Old Mar 15, 2009 | 12:57 PM
nomadjeep's Avatar
I have swapped in a tpi motor in my jeep. 91 Camaro motor-stock, 52 mm throttle body, all new sensors, stock exhaust manifolds.
It fired up and is running well, but the idle is about 1200 rpms. That is with the timing advanced 10 (after) tdc.
I do not think I have any vaccum leaks.
Do I have to do something special with the throttle position sensor? Could that be causing it.
Old Mar 15, 2009 | 01:17 PM
paulo57509's Avatar
Car: '87 IROC
Engine: LB9
Transmission: TH700R4
Re: High idle, timing questions.
Q: Why are you running the timing so retarded?
Old Mar 15, 2009 | 01:23 PM
nomadjeep's Avatar
it was the only way to lower the idle.
MustangBeater20
Oct 29, 2022 09:20 PM
specialized
Jun 18, 2022 09:26 AM
Spyder_TheGamer
Dec 25, 2015 05:07 PM
squiggy2
Aug 9, 2015 09:30 PM
