Cool TPI project..... Enjoy!
Old Mar 15, 2009 | 06:55 PM
1bad91Z's Avatar
Car: Faster
Engine: Than
Transmission: You!
This is a '58 Chevy truck that my boss and I are building for a customer. Motor is a cammed 327 ci with a TPI that we tricked out a bit.
We're not finished with it yet, still have some wiring and misc. fabrication to do........
Attached Thumbnails Cool TPI project..... Enjoy!-58tpi1.jpg   Cool TPI project..... Enjoy!-58tpi2.jpg   Cool TPI project..... Enjoy!-58tpi3.jpg
Old Mar 15, 2009 | 07:03 PM
FormulaL98's Avatar
Car: 88 Formula, 72 Nova, 68 Chevelle
Engine: L98, mild 350, L79 327
Transmission: 700R4, M20, M20
Axle/Gears: 9b 327,10b 373, 12b 331
Re: Cool TPI project..... Enjoy!
Awesome truck!! I always liked the old Apache pick up's (especially 58's). The carbon fiber treatment on the runner and upper plenum looks really trick actually for being just a stock tpi set up! What did you use to pull that off? Personally I would want a little more carbon fiber under the hood (maybe valve covers?) after seeing how that tpi looks, but its stellar as is. Good work!
Nick
Old Mar 15, 2009 | 07:11 PM
1bad91Z's Avatar
Car: Faster
Engine: Than
Transmission: You!
Thanks! Keep in mind, we're not done yet..........
The truck is actually a Cameo, not Apache (different beds). Carbon fiber is painted on with a pattern.
Old Mar 15, 2009 | 07:24 PM
SiCkRs's Avatar
Car: 91Z28
Engine: 5.7 ls1
Transmission: 4l60e
That looks awsome how much is that worth
Old Mar 15, 2009 | 07:28 PM
Timothayyy's Avatar
Car: 1992 Firebird
Engine: 350TBI
Axle/Gears: Ford 9in 4.10
The carbon fiber painted onto the intake manifold looks really nice.
I wish I had the will and patience to make my engine bay even half as clean as that truck!
Old Mar 15, 2009 | 07:31 PM
RedHawkLB9's Avatar
Car: 89 Formy
Engine: carbed 355ci
Transmission: A4
Axle/Gears: 3.73 10 Bolt
freakin Beast!
Old Mar 15, 2009 | 09:24 PM
1bad91Z's Avatar
Car: Faster
Engine: Than
Transmission: You!
Another pic showing the Cameo bed...
Old Mar 15, 2009 | 09:30 PM
SiCkRs's Avatar
Car: 91Z28
Engine: 5.7 ls1
Transmission: 4l60e
And that is your job making custom jobs in a shop
Old Mar 15, 2009 | 09:31 PM
1bad91Z's Avatar
Car: Faster
Engine: Than
Transmission: You!
One of my jobs, yes.
Old Mar 15, 2009 | 09:36 PM
Stephen's Avatar
Car: 87 GTA
Now THATS what I call a stealth Throttle Body! Totally invisible!
Old Mar 15, 2009 | 11:13 PM
1bad91Z's Avatar
Car: Faster
Engine: Than
Transmission: You!
I have the throttle body apart right now because I'm either going to paint it or polish it. I'm going to use an LT-1 throttle body because it utilizes the correct sensors to plug into the harness/ECM that we're using (MEFI 4 ram-jet harness/ECM).
Old Mar 16, 2009 | 05:30 PM
SiCkRs's Avatar
Car: 91Z28
Engine: 5.7 ls1
Transmission: 4l60e
I would like to do that that is why i am going to mechanic and electrical and body shop classes right now in high school
Their is a trans am right now i want to buy for $600 and i have a 350 tpi from iroc can i just swap the engine and it will work or you dont recommend me to get that trans am
Old Mar 16, 2009 | 07:54 PM
1bad91Z's Avatar
Car: Faster
Engine: Than
Transmission: You!
I've been building cars for about 13 or 14 years, just sorta had the knack for it I guess......
As far as the Trans-AM, if you like the car and it's fixable without a whole lot of rust or body/frame damage, then I say go for it!
Old Mar 17, 2009 | 12:28 PM
TPI's Avatar
Car: '89 Trans AM/'88 GTA
Engine: (2) Tuned Port L98's
Im diggin' the carbon fiber.. Great job guys!
Old Mar 18, 2009 | 07:40 AM
1bad91Z's Avatar
Car: Faster
Engine: Than
Transmission: You!
We may end up changing the valve covers for carbon fiber as well. I will probably end up painting the throttle body.
Old Mar 18, 2009 | 04:42 PM
SiCkRs's Avatar
Car: 91Z28
Engine: 5.7 ls1
Transmission: 4l60e
Yea the car is fixable and has no rust and all it needs is just the inke to run
And also i would like to know were you get that carbon fiber parts i would like that on my car
Old Mar 18, 2009 | 05:03 PM
1bad91Z's Avatar
Car: Faster
Engine: Than
Transmission: You!
The carbon fiber parts are stock TPI parts that were painted with a pattern.
Old Mar 23, 2009 | 11:11 PM
1bad91Z's Avatar
Car: Faster
Engine: Than
Transmission: You!
I had a request for an interior shot...... here ya go!
Old Mar 24, 2009 | 03:37 PM
d2harris's Avatar
Car: 92 Camaro Z28
Engine: 5.7 350 TPI
This truck is sweet! Great Job!
Old Mar 25, 2009 | 07:47 AM
1bad91Z's Avatar
Car: Faster
Engine: Than
Transmission: You!
Thanks! We think the owner will feel the same when he see's it!
I'll have some updated pics this weekend or so.
We had to use a modified '93 LT-1 throttle body which is installed now and the computer is mounted, air filter installed, and coil mounted....
Still need to finish up the wiring, make and the run the braided fuel lines, make a hard line for PCV to throttle body and some other little stuff....
Old Mar 29, 2009 | 05:44 PM
1bad91Z's Avatar
Car: Faster
Engine: Than
Transmission: You!
Still not finished yet, but we made some more progress....
Attached Thumbnails Cool TPI project..... Enjoy!-58tpi7.jpg   Cool TPI project..... Enjoy!-58tpi8.jpg   Cool TPI project..... Enjoy!-58tpi9.jpg
Old Mar 30, 2009 | 04:49 PM
SiCkRs's Avatar
Car: 91Z28
Engine: 5.7 ls1
Transmission: 4l60e
How do you happen to paint it like that
Old Apr 20, 2009 | 12:12 AM
1bad91Z's Avatar
Car: Faster
Engine: Than
Transmission: You!
She's runnin' and on the road. We changed to the new style SVO injectors and went ahead with the carbon fiber valve covers and breathers, plus a couple of other misc. mods.....
Old Apr 20, 2009 | 06:54 AM
Justin89Formy's Avatar
Car: 89 formula 350
Engine: ls1 magnuson tvs2300 supercharger
Axle/Gears: 4.11 Dana 44!
that truck looks really nice but man those headers are going to RUST and take away from the whole engine bay
Old Apr 20, 2009 | 08:17 AM
86T/A_Ram_Air's Avatar
Car: 91 Trans Am
Engine: 355 TPI
Transmission: Built T-5
if the engine bay was the roomy is all third gens we would all have headers lol.....sweeeett truck though
Old Apr 20, 2009 | 09:18 AM
reaper_Z28's Avatar
Car: 89 RS
Engine: stock TBI 305 atm
where did you get the pattern for the carbon fiber look? this truck is too f*ing sweet!!!
Old Apr 20, 2009 | 09:41 AM
1bad91Z's Avatar
Car: Faster
Engine: Than
Transmission: You!
Pattern was done by spraying base coat and then pattern place on top of base coat in darker color.
Headers are jet-hot coated like the rest of the custom dual exhaust that we built. They wont rust....
Old Mar 19, 2010 | 09:47 PM
1bad91Z's Avatar
Car: Faster
Engine: Than
Transmission: You!
ttt- so that a friend of mine can see the pics without having to search....
gta90
Sep 15, 2015 04:00 PM
fbirdroller
Sep 2, 2015 10:27 PM
Thornburg
Aug 26, 2015 07:22 PM
RedLeader289
Aug 17, 2015 08:22 AM
Sanjay
Aug 12, 2015 03:41 PM
