Help w/1.6 rockers
Old Mar 16, 2009 | 06:06 PM
89IrocZ350TPI's Avatar
Car: ws6
Engine: ls1
Transmission: m6
Help w/1.6 rockers
Hey guys. I am thinking about upgrading to 1.6 rockers. I have a full bolt on L98 running 13.2's with 300 hp at the crank. Do you think this upgrade would be worth the money? What kind of performance gains would one see?
Old Mar 18, 2009 | 06:35 PM
Car: ws6
Engine: ls1
Transmission: m6
Re: Help w/1.6 rockers
bump
Old Mar 18, 2009 | 07:55 PM
3rdgenred's Avatar
Car: 6.7 Powerstroke
What do rockers do anyway? I always hear people saying 1.6 to 1.....does it increase your lift duration? Does that mean it'll bump the int/exhaust on your cam?
Old Mar 18, 2009 | 08:02 PM
evilstuie's Avatar
Car: 1985 Pontiac TransAM
Engine: 400SBC 24x conversion
Transmission: T700r Stage2 Shiftkitted
Axle/Gears: 2.77 9 Bolt
Yeah I think thats what they do, but i think its something different.
Because people usually say use this cam and 1.6 rockers.... but why not just get a different cam....
so maybe it does something else?
but everyone says to do it whenever you mention wanting to get some hp out of your motor so cant hurt i guess.
Old Mar 18, 2009 | 10:12 PM
Car: ws6
Engine: ls1
Transmission: m6
Yes but I do not have enough money for a cam.
Old Mar 18, 2009 | 11:21 PM
88fastgta's Avatar
Car: 1988 Flame Red Trans am GTA
Engine: Forged 355 4 Bolt, FIRST TPI
Axle/Gears: ls1 torsen 3.42 gear
1.6 rockers just increases the lift of a cam around .33 from standard 1.5 rockers..... your stock 89 cam is .415/.430 with 1.6 rockers it will boost it up to .448/.463.. you might feel a little something.... there are different types of rockers... we have crappy stamped rockers... the are very innacurate and go from 1.39 to 1.52.... roller tips rockers are much better and stay at a constant lift..... roller tips also reduce friction.... so yes it does help.....
Old Mar 18, 2009 | 11:24 PM
Car: ws6
Engine: ls1
Transmission: m6
TPIS claims 15 hp
Old Mar 19, 2009 | 07:24 AM
88fastgta's Avatar
thats what they say.... but that is not true..... more like 5 or 6whp if that...... you have to remember that it also depends what your running.... they might be running no accesories with a much better intake with long tubes.... horsepower doesnt stack up like that... it all depends what you got and the right combination...
Old Mar 19, 2009 | 10:53 AM
Car: ws6
Engine: ls1
Transmission: m6
They prob meant 15 at the motor?
Right now I have a full bolt on L98. So maybe this mod is not worth the 134 dollars? This is a street car so I am only looking to add about 20 more horse power.
Old Mar 19, 2009 | 10:56 AM
Car: ws6
Engine: ls1
Transmission: m6
Maybe some after market pulleys would yeild better gains for the money. Mods are in sig. Only other things I can think of are the pulleys, rockers, and a 2800 stall which I cannot afford.
Old Mar 19, 2009 | 03:05 PM
FormulaL98's Avatar
Car: 88 Formula, 72 Nova, 68 Chevelle
Engine: L98, mild 350, L79 327
Transmission: 700R4, M20, M20
Axle/Gears: 9b 327,10b 373, 12b 331
Personally I dont think underdrive pulleys are all they're cracked up to be, I didnt notice any difference nor did my et's drop any after installing mine. I think the 1.6's are worth the investment, My brothers old Lt1/auto car dropped about 3 tenths consistantly after we installed them with fresh springs. Since you have your L98 moving more air with your intake and exhaust mods there is no reason you shouldnt see gains in the 15hp range.
Old Mar 19, 2009 | 04:57 PM
Car: ws6
Engine: ls1
Transmission: m6
Thx for the responses. Do you know which ones I need? There are a bunch of different 1.6 sizes.
http://tpis.com/index.php?module=cat...ry=Rocker+Arms
700-301 Rockers, Aluminum 1.6 x 3/8........$124.00
700-303 Rockers, Aluminum 1.6 x 7/16........$124.00
700-311 Rockers, Steel 1.6 x 3/8........$134.50
700-313 Rockers, Steel 1.6 x 7/16........$155.00
Also do I need to order springs as well?
Old Mar 19, 2009 | 05:48 PM
FormulaL98's Avatar
It's always good to put on some fresh valve springs, quality stock replacements will do fine. Also, since you would have the springs off anyway new valve seals would also be something to consider. Whatever rockers you go with need to be 3/8" stud and self-aligning.
Old Mar 19, 2009 | 05:54 PM
evilstuie's Avatar
Just out of curiosity... what cam do you currently have in it?
Is it a 300hp crate motor or have you done your own mods to get it to 300ponypower?
Old Mar 19, 2009 | 07:30 PM
rdog30's Avatar
Car: 85&95 Trans am
Engine: 85-LT1 95-LT1
Transmission: 4l60e & 4l60e
Axle/Gears: 3.23 & 3.23
Those prices are for a set of 8. You would have to double the price. There are cheaper places to get your rockers from then TPIS.
Old Mar 19, 2009 | 07:58 PM
88fastgta's Avatar
yeah tpis has very high prices for everything...... i don't like them....
Old Mar 19, 2009 | 08:44 PM
Car: ws6
Engine: ls1
Transmission: m6
http://www.jegs.com/p/JEGS/831437/10002/-1
How do these look^^^
Maybe for the money under drive pulleys would be a better choice since both are probably worth ten or so horsepower.
Old Mar 19, 2009 | 09:04 PM
Car: ws6
Engine: ls1
Transmission: m6
Go to the website in my sig. Its a full bolt on L98 300 at the motor, 250 at the wheels.
Old Mar 19, 2009 | 09:33 PM
roughskinjrz's Avatar
Car: 86 Monte Carlo
Engine: Blown 489
Transmission: TH400
Axle/Gears: 9" 370s
underdrive pulleys are smaller diameter and weigh less, they purpose is to slow down accessories so it takes stress off the motor and give back stolen horsepower from stock accessories. your looking at about 15 horsepower from udnerdrive pulley and 6-7 from 1.6 roller rockers.
Old Mar 19, 2009 | 09:39 PM
Car: ws6
Engine: ls1
Transmission: m6
[QUOTE=roughskinjrz;4087107]underdrive pulleys are smaller diameter and weigh less, they purpose is to slow down accessories so it takes stress off the motor and give back stolen horsepower from stock accessories. your looking at about 15 horsepower from udnerdrive pulley and 6-7 from 1.6 roller rockers.[/QUOT
If I buy some can they work with the pre existing belts?
Old Mar 19, 2009 | 09:41 PM
Car: ws6
Engine: ls1
Transmission: m6
http://tpis.com/index.php?module=cat...ry=Pulley+Sets
I think I will get these.
Old Mar 19, 2009 | 10:20 PM
Shadygrady's Avatar
Car: 87 IROC Z
Engine: 5.7 L98 TPI
Transmission: 700r4,2500 stall
Axle/Gears: G80,10 bolt 3.42's
I`m curious how`d you get 300hp at the crank with those mods.I dont see 60 hp worth of bolt ons IMO.I`m not trying to call you a liar,that just seems like alot of power for a bolt on L98.Especially with a hypertech chip.You 1/4 time seems fast too.Must have been a factory freek or something.I`ve got tpis lower manifold,slp runners and ported plenum about to go on when I`m done porting it.Cant wait to see what they do to my car.
You may have to pull the heads and have alittle work done to get the 1.6`s to fit correctly.
Old Mar 19, 2009 | 10:33 PM
Car: ws6
Engine: ls1
Transmission: m6
Most full bolt on l98 cars in here make around 240-250 rwp which equals 300-310 with a 20 percent loss.
Old Mar 19, 2009 | 10:41 PM
Car: ws6
Engine: ls1
Transmission: m6
I think I got 306 for my car w/20 percent loss. If you think about how restrictive the stock headers and exhaust are it makes sense. You can pick up 30 hp by getting good headers/cat back w/high flow cats, and another 25 with a ported intake manifold and runners. Theres 55 right there.
Here is a firebird modded by slp that made an extra 50 horse power with far less mods than my car.
https://www.thirdgen.org/slptpibuild-hpp-feb89
I also have my slips and dynos if you are interested.
Old Mar 19, 2009 | 10:56 PM
Car: ws6
Engine: ls1
Transmission: m6
Here it is. There guys in the thread below are making even better power than my car. Orr89 was hitting 13.8's with just cat back/headers, and 2800 stall!!
https://www.thirdgen.org/forums/tpi/...get-stock.html
Old Mar 19, 2009 | 11:48 PM
Camaro383ci's Avatar
Car: 84 Berlinetta
Engine: Bottle Fed 383ci
Transmission: Stage2 T56 Ram powergrip HD clutch
Axle/Gears: Ford 9" Detroit tru track 4.11 gear
I'd do both 1.6's plus the pulleys. lol. thats good for 20-25 whp. get the performance pulleys and not the high flow water ones. IMO i'd try to stay away from stamp rockers if for a few buck more the full roller rockers (less friction) would be the best gain in performance.
Old Mar 19, 2009 | 11:56 PM
Car: ws6
Engine: ls1
Transmission: m6
I think I'll just go with the pulleys. All I really wanna hit is a 12.9 and I think I can with pulleys and slicks.
Old Mar 20, 2009 | 09:49 AM
Car: 86 Monte Carlo
Engine: Blown 489
Transmission: TH400
Axle/Gears: 9" 370s
id opt for pulleys over the rockers right now. slicks will help alot with your 60 foot to good luck let us know how it works.
Old Mar 20, 2009 | 10:40 AM
LB9Iroc87's Avatar
Car: 1987 Iroc-Z28
Axle/Gears: G92 3.23, G80, J65 disc
I would go with the set of 1.6 or 1.65 roller rockers. Check out some other places then TPI's there always high on everything. Look in summit or jegs or sumthing. Youll get slightly better gas mileage out of them to, and a consist lift unlike our shitty stamped rockers. But its your choice, and with the mods that u have on your car you mite see a few tenths in the quarter with this upgrade.
Old Mar 20, 2009 | 10:45 AM
FormulaL98's Avatar
Old Mar 20, 2009 | 01:15 PM
tinymay's Avatar
Engine: 5.7 TPI
Here's the ones I went with. I ran them before on another engine with underdrive pulleys and they definitely made a difference. I bought another set for my current project and will put them in as soon as I find the time. You will feel the difference, for sure.
http://www.jegs.com/i/Proform/778/66925C/10002/-1
http://store.summitracing.com/partde...C&autoview=sku
Old Mar 20, 2009 | 07:38 PM
Car: ws6
Engine: ls1
Transmission: m6
im feelin the pulleys just cuz I can install them in 30 mins haha
Old Mar 20, 2009 | 11:35 PM
Shadygrady's Avatar
Car: 87 IROC Z
Engine: 5.7 L98 TPI
Sorry to be off topic.Once again.Not saying you`re full of bs.I`m aware its possible.As I`m aware of orr`s car and others who get deep 13`s or better with a stock head & cam L98.Usually hypertech chips are junk.Orrs car was tuned and tuned well when he got his best numbers.Stall,full exhaust,slicks I can see a 13.8.All I`m really saying is I cant wait to get my new intake and injecters in to see what it does.Ive never run the right size slicks on a full 1/8 or 1/4.I borrowed some slicks one time but they where 28" tall and killed my gear.Come to find out that the track I went to was not a full 1/8th.It was a 130' short.Figured something was wrong when I dialed a 7.1 my first run.I got 8.7 on crappy street tires on a full 1/8th.Just wonder if I can expect 30 hp with new ported intake with my current mods...or hopefully even better.I`m just not sure if its there.BTW,that 8.7 was with flowjunk headers and y pipe,2.73 gear and stock stall.
I do want to know what the underdrive pulleys do for you.20 hp?I`ve read alot of guys had problems with the car not charging or cooling like it should.I`d like to know for sure if such an easy bolt on makes any real differance without any adverse effects.I`ve almost bought some several times just to research it and read its not worth it.I`d like to be told differantly with some decent proof.
I would be interested to see or hear(read) what your timeslips were so I could compare to what mine where on that short track up to the last point they timed.Have to look at them again to find out what that was.
Old Mar 20, 2009 | 11:44 PM
Car: ws6
Engine: ls1
Transmission: m6
The funny thing is the hypertech makes better power than a TPIS chip I bought. My best mod was def going from 2.77 gears to 3.45's. Best run with the 2.77's was 13.7 on street tires I believe. I posted my dyno numbers on here awhile back, not sure exactly where. I had the car dynoed 3-4 times and the power ranged from 245rwh to 252whp, and 342rwt. Havent had the car dynoed yet with the new injecters so it may be a bit higher. When I had the gears installed the guy asked me if I had a cam in the car because he said it is very fast for what it is.
EDIT- 245whp w/TPIS chip 251whp w/Hypertech chip
Mutillator
Exterior Parts for Sale
Jan 2, 2016 06:44 PM
tcarlos13
Interior Parts Wanted
Sep 28, 2015 06:31 PM
New2Chevy
Sep 28, 2015 12:35 AM
Billyadams
Sep 22, 2015 08:25 AM
ericjon262
Sep 11, 2015 06:07 PM
