87 TA 5.0 TPI Standard( Bucking/skips
Old Mar 19, 2009 | 08:40 PM
seventy77's Avatar
Car: 87 GTA
Engine: 5.0
Transmission: 5spd
Axle/Gears: 3:45
Hey,
I'll try to explain as best as i can.Recently bought this car.It bucks alittle when taking off.Mainly 1st gear,but in second too when cold.Mainly below 2000 Rpm or less,and seems to do it worse when it's cold..But once warmed up,( after half hr of driving, not as bad) I know the IAC Valve was replaced new.But have no idea..Not familiar with TPI.And no engine light...Somebody said it may be the throttle cable sticking??? Any tips would be great!!!
Thanks,
Mark
Old Mar 19, 2009 | 11:31 PM
86T/A_Ram_Air's Avatar
Car: 91 Trans Am
Engine: 355 TPI
Transmission: Built T-5
Re: 87 TA 5.0 TPI Standard( Bucking/skips
do you have any RPM surge when this happens?
Old Mar 20, 2009 | 09:22 AM
seventy77's Avatar
Car: 87 GTA
Engine: 5.0
Transmission: 5spd
Axle/Gears: 3:45
You mean does the rpm drop?? When im out today,i'll pay atten to the rpm..I just know it happens under 2000..
Old Mar 20, 2009 | 02:55 PM
Car: 91 Trans Am
Engine: 355 TPI
im going to guess you are having some sort of vacumm leak
Old Mar 21, 2009 | 12:39 AM
boldguy's Avatar
Car: 1992 Z28
Transmission: World Class T-5 5speed manual Trans
Axle/Gears: STOCK G92 performance 3.42
could be a misfire combined with some normal backlash from a geared car. With an auto any slop (backlash) is taken up through the torque convertor. listen to the car idle and if you hear any hiccup, youve got problems, then rev it to the problem area and see if you can hear any misfire... thats what i would do and have done before.
1992rs/ss
Jan 31, 2025 05:10 PM
Caspar
Jun 19, 2016 11:19 PM
ron reece
Southern California Area
Oct 7, 2015 01:11 PM
Sanjay
Aug 12, 2015 03:41 PM
