zz4 cam or hot cam
Old Mar 16, 2009 | 11:04 PM
camaro350tpi's Avatar
Car: camaro iroc-z 89
Engine: 383 HSR SC MegaSquirt
Transmission: tko 600
Axle/Gears: 9 Inch 3.75
zz4 cam or hot cam
hi all , ived read some info about those cam but im esitated witch one should i get for my car . ill leave the l98 iron heads with the needed modification to get at least .550 inch of lift ... and i just want to know your opinion about those cams witch one his better on a 350 tpi. thanks
Old Mar 17, 2009 | 08:09 AM
305sbc's Avatar
Car: 1986 Irocz
Axle/Gears: 3.25:1
Re: zz4 cam or hot cam
http://temp.corvetteforum.net/c4/vader86/cam.html
The ZZ4 should work well and require much less modification and adjustment.
If you're going to do some head porting and other cylinder head modifications to allow and take advantage of higher lifts and a higher power band, along with custom tuning, then the hotcam should be better.
Old Mar 17, 2009 | 08:31 AM
tony_cogliandro's Avatar
Car: 1990
Axle/Gears: stock
its obvious you know your stuff. i put your chart on my permanent cam list. its great.
i have someone trying to sell me a cam that is supposed to be 191/196 418/430 111 and is calling it an lt1 lt4.
that is really mild - and i cant find it on any chart. ever heard of it?
thanks.
Old Mar 17, 2009 | 08:44 AM
Hawk92z-TDZ's Avatar
Car: 92Z28, 99SS, 83Z28 & 86GTA
Engine: 421, LS1, 327Turbo & 383
Transmission: T-56, 4L60E, T5 & 4L60
Axle/Gears: 4:10, 3:42, 2:73 & 3:27
" 191/196 418/430 " looks close to the B-bODY lt1 cam, but I would have to look it up to be sure
If staying a LTR I would be more apt to suggest the ZZ4
Old Mar 17, 2009 | 10:20 AM
305sbc's Avatar
Car: 1986 Irocz
Axle/Gears: 3.25:1
thanks.
Thanks, but it's not MY chart or list. I just refer to it often.
That cam doesn't ring a bell but it looks like typical stock GM for a 350.
Old Mar 17, 2009 | 10:40 AM
Atilla the Fun's Avatar
On Probation
Engine: several
Transmission: none
Axle/Gears: none
I think that tiny cam is the L31 cam
Old Mar 17, 2009 | 07:32 PM
Kevin91Z's Avatar
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
With stock heads, I'd stick to the ZZ4 camshaft. You'll still need to get new springs, retainers, and valve stem seals (Manley parts, of course ) but the stock heads dont flow well enough to work with the hot cam.
Old Apr 10, 2009 | 09:16 AM
THE HOFFMEISTER's Avatar
Car: 89 Trans Am GTA
If you have a L98 then i cant see the point in all the work involved to just swapover to a ZZ4 cam.
Sure its an improvement, but not much of one, especially considering the expense and the labour involved.
Much more worthwhile to save for a better set of heads and then
it would be worth the effort, (with a larger cam of course)
Old Apr 10, 2009 | 10:03 PM
89IrocZ350TPI's Avatar
Car: ws6
Engine: ls1
Transmission: m6
zz9 cam
sweet_87_iroc
Sep 25, 2015 10:01 PM
angel2794
Sep 8, 2015 06:22 PM
f-bodyz28
Sep 2, 2015 05:03 PM
theurge
Aug 21, 2015 12:46 PM
355tpipickup
Aug 13, 2015 07:35 AM
