stealth ram on 350 tpi question.
Old Mar 17, 2009 | 10:58 AM
cmtison's Avatar
Car: 1992 B4C
Engine: L98 soon to be 383
im putting on SB Chevrolet Vortec Cylinder Head and Weiand Stealth Ram wich includes base and plenum what i need to know is if the stock 350tpi fuel lines/ injecters will fit the Stealth Ram
Old Mar 17, 2009 | 07:30 PM
Kevin91Z's Avatar
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
Re: stealth ram on 350 tpi question.
The injectors will work, but you must use the fuel rails for the Stealth Ram. Stock ones will not fit.
9192camaro
16
Feb 3, 2019 12:21 AM
ASE doc
Alternative Port EFI Intakes
Aug 25, 2015 09:14 AM
Out-Cast
Aug 17, 2015 10:57 AM
wruiz
Aug 13, 2015 09:07 PM
L98GTA87
Aug 11, 2015 06:55 PM
