egr..
Old Mar 22, 2009 | 11:34 PM
nascar2496's Avatar
Car: 1986 Camaro IROC-Z
Engine: 305 tpi
Transmission: BW t5 W/ short shifter
Axle/Gears: 9 Bolt 3.27 posi
egr..
So im putting vette heads 113's on my 305..they dont have an egr passage and im not about to put the stock log type exhaust on it just for an egr valve.
Does anyone know if i can pass NJ emissions without it? Will it hurt the performance of the engine or anything of the such?
thanks!
Old Mar 23, 2009 | 01:04 PM
Kevin91Z's Avatar
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
Re: egr..
for Corvette EGR on the TPI board. I've posted my previous setup with headers and there have been a couple other threads on this topic recently.
Yes its possible to pass smog without it hooked up, depending on your camshaft. But you will probably also get a Code 32 while driving, as well.
Old Mar 23, 2009 | 02:31 PM
jv9999's Avatar
Car: '87 IROC/'68 SS
Engine: 5.7L/350
Transmission: 700R4/Muncie 4-spd
Axle/Gears: 3.27 9 bolt / 3.31 12 bolt
Re: egr..
You can get a PROM burned that will eliminate the EGR and the code 32. If NJ is still sniffing tailpipes I doubt it will pass (high NoX) though.
Old Mar 23, 2009 | 06:06 PM
86T/A_Ram_Air's Avatar
Car: 91 Trans Am
Engine: 355 TPI
Transmission: Built T-5
Re: egr..
nj still does a sniff test for ALL OBD1 cars
89newfun
Jun 10, 2010 02:51 PM
White25thZ28
May 28, 2008 06:06 PM
Travis&camaro
Nov 16, 2007 07:03 PM
Jay
Jul 13, 2007 09:24 PM
5.7iroc-02ws6
Alternative Port EFI Intakes
Mar 11, 2007 04:24 AM
