406 tpi idle problems
Old Mar 26, 2009 | 11:32 PM
406vette's Avatar
my name is dustin i have a 1986 corvette the 350 went out and i had a 406 laying around.its an auto has 30lb injectors a comp cam rebuilt cast l98 heads steel 1.5 roller rockers jet adjustable fuel pressuer regulator heads and intake are ported and pollished its internaly ballanced 2.5 pipes back to resanator tips the only thing i left un touched was the distrubuter for now replaced plug wires.
i had to unplug the cold start injector and finaly got it to run but the idle has to be set at 1300 and still isnt smoth havent driven car but runs strong when given throtle. is the poor idle due to the large engine and outher parts wile still running the stock chip? any ideas how to improve this for the time being should i put the stock injectors in and see what happens. i am ordering everything from moates to emulate log and burn but it will be a while. plans are new heads nitrious pos twin turbo. any feed back appreciated. cs nx262H-13 cam specs
intake: lift.462,duration 262
exhaust: lift.480 duration 280
it is made for nitrious and turbocharged applications 113 lobe sep.
i am still missing my temp sensor wire and the sensor that is on the plenum above the fuel press reg beieve air temp? does anyone know what collor they are i coul follow the temp and air sensor wires from the fire wall to find them. have looked for hours.
Infested
May 22, 2018 11:56 PM
Wade787b
Sep 29, 2015 01:15 PM
db057
Aug 22, 2015 08:17 PM
Sanjay
Aug 12, 2015 03:41 PM
