will my 305 tpi set up work on this engine
Old Mar 31, 2009 | 02:29 PM
wht91z28's Avatar
Car: 1991 camaro z28
Engine: 305cu/tpi
Transmission: auto
i have no clue but will this engine work in 91 z with my 5.0 tpi set up on it or will i have to convert my car to carb? Thanks for the help. http://paceperformance.com/index.asp...D&ProdID=22746
Old Mar 31, 2009 | 02:41 PM
battman's Avatar
Car: 87 GTA, 88 GTA, 92 TA, 72 RS SS
Engine: 350, 350, 305, 396
Transmission: T56, 700r4, 700r4, T56
Axle/Gears: 3.42, 3.23, 3.23, 3.73
Re: will my 305 tpi set up work on this engine
you will have to buy a vortec TPI intake base to make it work, everything else will bolt up.
Old Mar 31, 2009 | 03:42 PM
wht91z28's Avatar
Engine: 305cu/tpi
Transmission: auto
the cam will it work with my computer, distributor everything? I mean everything. I am really cluessless about engine stuff as far as swapping. all I have to do is bolt my stuff on.
Old Mar 31, 2009 | 05:19 PM
kcallais's Avatar
Car: 1985 Z28
Axle/Gears: garbage 2.73
Youre going to need a tune and bigger injectors.
Old Mar 31, 2009 | 11:40 PM
Kevin91Z's Avatar
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
That engine also uses a flat-tappet cam: yuck. Stick with hydraulic roller cams, they're much better in terms of longevity, gas mileage, emissions, and horsepower.
And you should never have to downgrade your car to carb. There arent as many TPI friendly combos out there anymore, since our cars are 20+ years old, but there have been many combos posted on these boards over the years. You just have to open up your wallet.
jaridjohn
Jul 8, 2024 03:49 PM
BlueIroc-Z
Jun 9, 2019 03:22 AM
1nastygta
Oct 28, 2015 08:51 PM
Brcharrelson
Aug 26, 2015 07:47 PM
drathaar907
Aug 6, 2015 04:20 PM
