TBI to TPI - Car Swap
Old Mar 31, 2009 | 06:34 PM
TransAmRocker's Avatar
Ok, I have been going over this in my head but I am not sure either way. I have a 1988 Trans Am that I put a 350TBI engine into, I also have a 1988 GTA. What will I need to do to convert the 350TBI engine to a 350TPI engine?
Old Mar 31, 2009 | 10:24 PM
86T/A_Ram_Air's Avatar
Car: 91 Trans Am
Engine: 355 TPI
Transmission: Built T-5
Re: TBI to TPI - Car Swap
harness, ecm, tpi manifold for starters
Old Apr 1, 2009 | 06:16 AM
The GTA is already setup for TPI since it came stock with it. All I would think I would need is to put the manifold on the engine and slap it in since the GTA already has a 350TPI setup.
Old Apr 2, 2009 | 02:43 PM
battman's Avatar
Car: 87 GTA, 88 GTA, 92 TA, 72 RS SS
Engine: 350, 350, 305, 396
Transmission: T56, 700r4, 700r4, T56
Axle/Gears: 3.42, 3.23, 3.23, 3.73
Try the stickey at the top of the page:
http://https://www.thirdgen.org/foru...d-density.html
I did it on a 305 tbi rs and it worked great.
Old Apr 3, 2009 | 12:54 PM
Keep getting "address not found" for that link, kinda the downfall of the ... in the address bar eh. The thing is this, the ECM/Harness is already in the GTA. Can I just bolt the TPI intake onto the TBI block to put the block into the GTA and drive it.
Im not trying to make the entire car TBI to TPI just converting the TBI BLOCK to make it TPI.
Old Apr 9, 2009 | 10:37 PM
dwolfe88's Avatar
Is there another link somwhere I can't get this one to work. I'm in a hole and really need that link. Thank You
Old Apr 11, 2009 | 11:20 AM
birdtojag's Avatar
Car: 87 Firebird, 90 bird coming soon
Engine: 355 Chevy Vortec Heads TPI, LT1 inj
Axle/Gears: 2.77 posi 9-bolt
Intake, harness, sensors, fuel line connectors and ECM. Maybe a dual fan set-up if you want to go that route. You can just bolt it up, plug it in and play.
MustangBeater20
Oct 29, 2022 09:20 PM
1nastygta
Oct 28, 2015 08:51 PM
Wade787b
Sep 29, 2015 01:15 PM
NBrehm
Aug 25, 2015 11:49 PM
drathaar907
Aug 10, 2015 07:44 AM
