MAF & MAP??
Old Mar 31, 2009 | 09:35 PM
86T/A_Ram_Air's Avatar
Car: 91 Trans Am
Engine: 355 TPI
Transmission: Built T-5
MAF & MAP??
someone told me that even though my car is a MAF system i also have a MAP sensor.....is this true? i was under the impression that you either have one or the other on these cars
Old Mar 31, 2009 | 09:41 PM
kcallais's Avatar
Car: 1985 Z28
Axle/Gears: garbage 2.73
Re: MAF & MAP??
You have a MAF sensor, then a Manifold Air Temp sensor under the plenum if I recall correctly, not a Manifold Absolute Pressure sensor. MAF/MAT and MAP/MAT.
Old Mar 31, 2009 | 09:45 PM
Car: 91 Trans Am
Engine: 355 TPI
Re: MAF & MAP??
yeah i know about the MAF/MAT, but never a MAP, so after i heard this i went on rock auto and sure as s*hit the not only have a sensor, but a pigtail too. for an 86 TPI 5.0......i was almost in shock
Mark_ZZ3
May 24, 2018 01:02 PM
BumpaD82
Feb 26, 2016 02:57 PM
racereese
Oct 3, 2015 03:46 PM
aaron7
Sep 30, 2015 09:15 AM
